ADGuard and 388.1 firmware: problem with WIFI ?
Hi
I was thinking about it .... in fact when I changed the router to not use the old case and the old ssd, I put new ones.
But I see it :rolleyes:
do you have any idea ?
Hi
Just get something small like 32gig and a popular brand like kingston, sandisk etc. They are at least reliable for the most part. I have a sandisk cruzer fit 64gig and it works on USB3 no problem.
Hi
As case ?
Hi
no problem … :)
The external case … I use now this :
Hi
no problem … :)
That is a nice drive, however, the USB port wasn't designed to handle a NAS like device. If you're sharing files and such sure, maybe even play a video, but any high use demand and it will fail to provide you that kind of performance.
Hi
I use it only for swap file, for entaware, AdGuard and for.....fresh_qos (but I'm not sure if it's on the external drive)
Better to use a usb key?
Hi
I see. Fresh QOS isn't on the USB drive. Skynet and Entware are the usual scripts that do.
Hi
Yes, a small sized USB key. Like I said a 64gig is a huge USB drive for these routers considering what they are use for. Mostly samba share stuff. Even using them for cloud storage is a debatable topic for sure.
Hi
Thanks, I try with a key :)
Hi
I tried with a USB3 sandisk key. No problems, you gave me a great suggestion.
Grazie
