Aegis aegis: a firewall blocklist
What happens when you run
"aegis upgrade"
I know aegis 1.1.4 is installed on my usb drive,that will just upgrade internally
oot@R7800:/$ aegis upgrade
Upgrading:
- Version installed: 1.0.3
- Version found: 1.1.4
? Do you want to upgrade from 1.0.3 to 1.1.4 (y/n)?
Ok, clearly at some point, something got messed up.
The aegis in your internal drive is not installed in the right place /root/bolemo...
So it is a mystery where it is and how it ended up there...
Can you do this:
ls -l /opt/bolemo
And this:
ls -l /usr/bin/aegis
It will tell where the symlink is pointing to for your internal aegis.
From there, we can figure out how to uninstall this copy.
Can you do this:
ls -l /opt/bolemo
And this:
This is what I get
root@R7800:/$
root@R7800:/$ ls -l /opt/bolemo
lrwxrwxrwx 1 root root 20 May 27 19:30 /opt/bolemo -> /tmp/mnt/sdb1/bolemo
root@R7800:/$
root@R7800:/$ ls -l /usr/bin/aegis
lrwxrwxrwx 1 root root 25 May 27 19:30 /usr/bin/aegis -> /opt/bolemo/scripts/aegis
root@R7800:/$
root@R7800:/$
All of that is right.
It means that aegis is installed on external drive.
So you have version 1.0.3 on your external drive sdb1.
I would do a reinstall from install script.
This is what I get
root@R7800:/$
root@R7800:/$
root@R7800:/$
root@R7800:/$
Ok I get this now. Dont understand whats happened to the internal aegis and things are still not right. Might do a factory reset and start again
root@R7800:/$
root@R7800:/$ wget -qO- https://github.com/bolemo/aegis/raw/master/aegis-install.sh | sh
Where do you want to install aegis?
0 - router internal memory (rootfs)
1 - external drive: /mnt/sda1
2 - external drive: /mnt/sdb1
c - cancel installation
Your choice: 2
aegis will be installed on external drive /tmp/mnt/sdb1
Creating directory (if not already existing): /opt/scripts
Creating directory (if not already existing): /tmp/mnt/sdb1/bolemo
Creating symlink (if not already existing): /opt/bolemo
Creating subdirectories in bolemo: scripts, etc
Downloading and installing aegis...
An aegis sources file already exists, keeping it.
iprange is installed.
Done!
root@R7800:/$
root@R7800:/$ aegis info
Info:
- 'aegis' version 1.1.4 is installed on external drive.
- 'aegis' is in PATH.
- This is the last version.
- 'iprange' is installed: iprange 1.0.4
root@R7800:/$
root@R7800:/$ aegis status
Status:
- 'aegis' version: 1.1.4
- Something is not right with iptables setup! Use 'aegis -v status' for more details
- Logging is off.
root@R7800:/$
root@R7800:/$
root@R7800:/$ aegis -v status
aegis 1.1.4 - Verbose mode
Status:
- Logging is off.
Detailed status:
- 'firewall-start.sh' exists with correct settings.
- 'post-mount.sh' exists with correct settings.
- Actual router time: 2020-05-29 19:24:45
- Blocklist generation time: 2020-05-26 03:15:04
- Router firewall was last started 2020-05-29 18:43:23:
ipset blocklist was already loaded.
outbound iptables rules were already set!
iptables logging rules were set.
- iptables rules are not set properly:
iptables rules are not set for VPN tunnel
iptables -N aegis_DROP
iptables -A INPUT -i brwan -m set --match-set aegis_BL src -j aegis_DROP
iptables -A FORWARD -i brwan -m set --match-set aegis_BL src -j aegis_DROP
iptables -A FORWARD -o brwan -m set --match-set aegis_BL dst -j aegis_DROP
iptables -A OUTPUT -o brwan -m set --match-set aegis_BL dst -j aegis_DROP
iptables -A aegis_DROP -j LOG --log-prefix "[aegis] "
iptables -A aegis_DROP -j DROP
- Logging is inactive.
- ipset blocklist is not set.
- ipset whitelist is not set.
- ipset WAN gateway bypass is not set.
root@R7800:/$
root@R7800:/$
Good :)
Now, just do
aegis clean -v
And
aegis update -v
PS: you have 2 external drives. Maybe you had aegis on both...
PSS: no need to factory reset
root@R7800:/$
Your choice: 2
Done!
root@R7800:/$
Info:
root@R7800:/$
Status:
- Logging is off.
root@R7800:/$
root@R7800:/$
Status:
- Logging is off.
Detailed status:
root@R7800:/$
root@R7800:/$
All good.
Have a nice week-end @jrbmw
  • Like
Reactions: KW.
Aegis does it job so good. Not that i've ever doubted it. When I forgot all about this pearl of a software as its just do its work in shadows and with no drawback I was reminded when a streaming software stopped working and it didn't got a connection.
Then Aegis entered my mind again. As this pearl is build in such a well thought out way I got the blocked ip:s from the log and could whitelist them and all is now fine. It's all in the readme but as Im not as accurate as this software I had to run to HELLO wORLD. Great service comes with the software and he pointed out my typo in the file name.
Thanks HELLO wORLD for a great neat software with lovely simple commands and thank you for your service. My only problem now is if I should use that streaming software and why the IP:s was blacklisted. But that is my headache and its really valuable to have a shield that forces you to stop up and think and make conscious decisions. I recommend Aegis to everyone who can use it.
@Jauger, probably not, like all the other (more important) stickies just get ignored too.
installed on usb ........ but from error help
root@R9000:/$ aegis info
Info:
root@R9000:/$
root@R9000:/$ aegis update -v
Initializing...
- 'firewall-start.sh' is in place and ok.
- 'aegis' is installed on external drive.
- 'post-mount.sh' is in place and ok.
Updating blocklist from sources...
- Downloading lists defined in /opt/bolemo/etc/aegis.sources
1) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level1.netset
-                   100%[===================>]  41.56K  --.-KB/s    in 0.002s
2) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level2.netset
-                   100%[===================>] 291.01K  --.-KB/s    in 0.01s
3) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/firehol_level3.netset
-                   100%[===================>] 263.96K  --.-KB/s    in 0.01s
4) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/iblocklist_ciarmy_malicious.netset
-                   100%[===================>] 202.01K  --.-KB/s    in 0.02s
5) https://raw.githubusercontent.com/firehol/blocklist-ipsets/master/malwaredomainlist.ipset
-                   100%[===================>]  14.49K  --.-KB/s    in 0.001s
- Optimizing and reducing netset (using iprange)...
- Done.
Building ipset blocklist (49740 entries blocking 619488609 ips)...
- Created blocklist, swapping it.
- Done.
- Internal firewall needs to be restarted...
Restarting firewall...
/bin/sh: /etc/appflow/streamboost.d/40_qdiscman: not found
/usr/sbin/net-wall: /usr/sbin/net-wall: 107: /opt/scripts/firewall-start.sh: not found
- Firewall restarted.
Status:
- Something is not right! Use 'aegis -v status' for more details
- Logging is off.
Detailed status:
- Actual router time: 2020-10-19 21:59:37
- Blocklist generation time: 2020-10-19 21:59:37
- No status file found.
- iptables rules are not set.
- ipset blocklist is set:
     Type: hash:net
     Revision: 6
     Header: family inet hashsize 16384 maxelem 49740
     Size in memory: 1053748
     References: 0
     Number of entries: 49740
root@R9000:/$
root@R9000:/$ aegis status -v
Status:
- Logging is off.
Detailed status:
- Actual router time: 2020-10-19 22:00:00
- Blocklist generation time: 2020-10-19 22:00:00
     Type: hash:net
     Revision: 6
     References: 0
root@R9000:/$
Info:
root@R9000:/$
root@R9000:/$ net-wall restart
Starting Firewall...
Done!
root@R9000:/$
[CODE]root@R9000:/$ ls -l /mnt
lrwxrwxrwx    1 root     root            8 Sep  2 17:44 /mnt -> /tmp/mnt
root@R9000:/$
root@R9000:/$ ls -l /mnt/UNTITLED/
ls: /mnt/UNTITLED/: No such file or directory
root@R9000:/$
lrwxrwxrwx    1 root     root            4 Oct 19 21:37 New_Volume -> sdc1
drwxrwxrwx    1 root     root         4096 Oct 19 11:28 sdc1
root@R9000:/$
root@R9000:/$ ls -l /mnt/sdc1/bolemo/*
/mnt/sdc1/bolemo/etc:
-rwxrwxrwx    1 root     root       719046 Oct 19 21:59 aegis-bl.netset
-rwxrwxrwx    1 root     root          455 Oct 19 11:14 aegis.sources
/mnt/sdc1/bolemo/scripts:
-rwxrwxrwx    1 root     root        34932 Oct 19 21:04 aegis
/mnt/sdc1/bolemo/www:
-rwxrwxrwx    1 root     root         1052 Oct 19 12:30 aegis.htm
root@R9000:/$
root@R9000:/$ cd /opt
root@R9000:/opt$
root@R9000:/opt$ ls -l bolemo/*
bolemo/etc:
bolemo/scripts:
bolemo/www:
[/CODE]
It looks like the problem is not coming from aegis, but from when the firewall is restarted.
Can you first check if /opt/scripts/firewall-start.sh exists and cat its content?
In this line (returned by firewall restart, not aegis):
Bash:
It seems that the built-in firewall script is not able to find firewall-start.sh
Info:
root@R9000:/$
Initializing...
- Done.
- Done.
Status:
- Logging is off.
Detailed status:
     Type: hash:net
     Revision: 6
     References: 0
root@R9000:/$
Status:
- Logging is off.
Detailed status:
     Type: hash:net
     Revision: 6
     References: 0
root@R9000:/$
Info:
root@R9000:/$
Done!
root@R9000:/$
root@R9000:/$
root@R9000:/$
root@R9000:/$
root@R9000:/$
root@R9000:/opt$
bolemo/etc:
bolemo/scripts:
bolemo/www:
[/CODE]
  • Like
Reactions: KW.
root@R9000:/$ cd /opt/scripts/
root@R9000:/opt/scripts$
root@R9000:/opt/scripts$ ls
firewall-start-adguardhome.sh  firewall-start.sh
firewall-start-bwusage.sh
root@R9000:/opt/scripts$ vi firewall-start.sh
#!/bin/bash
iptables -I INPUT -s 51.79.162.132 -j DROP
iptables -I INPUT -s 51.79.142.79 -j DROP
iptables -A INPUT -p tcp --destination-port 50002 -j DROP
# Bolemo aegis
[ -x /opt/bolemo/scripts/aegis ] && /opt/bolemo/scripts/aegis _fws
Thank you.
First, the shebang should be #!/bin/sh (not bash), but that should not be the problem here.
Aegis did install its link, so the problem is definitely not aegis.
net-wall restart
  • Like
Reactions: KW.
Done!
root@R9000:/$
L blocklist not work with NordVPN NETGEAR AC Routers and Adapters (Wi-Fi 5) 0
