root@R7800:/$ aegis upgrade
Upgrading:
- Version installed: 1.1.3
- Version found: 1.1.4
? Do you want to upgrade from 1.1.3 to 1.1.4 (y/n)? y
- Downloading:
/tmp/aegis.dl 100%[===================>] 34.11K --.-KB/s in 0.04s
- Script installed to /opt/bolemo/scripts/aegis
root@R7800:/$ aegis status
Status:
- 'aegis' version: 1.1.4
- 'iprange' is installed: iprange 1.0.4
- Something is not right! Use 'aegis -v status' for more details
- Logging is off.
Well seems to be fixed with a router reboot.
aegis status -v
Heres the resultTry now running
aegis update and see if it's ok afterwards.
aegis status -v
iptables -S
aegis clean -v
net-wall restart
Heres the result
root@R7800:/$
root@R7800:/$ aegis update
iptables: No chain/target/match by that name.
iptables: Bad rule (does a matching rule exist in that chain?).
ip6tables: No chain/target/match by that name.
ip6tables: Bad rule (does a matching rule exist in that chain?).
root@R7800:/$
root@R7800:/$ RTNETLINK answers: No such process
Does this mean all is ok with aegis....before I try what you said
root@R7800:/$
root@R7800:/$ /opt/bolemo/scripts/aegis info
Info:
- 'aegis' version 1.1.4 is installed on external drive.
- 'aegis' is in PATH.
- This is the last version.
root@R7800:/$
Status:
- 'aegis' is set and active for WAN interface (ppp0) and VPN tunnel (tun21).
- Filtering 619883251 IP adresses.
- WAN gateway IP range does not need to be bypassed.
- Logging is on.
root@R7800:/$
I've noticed I've got it installed on USB but it didn't survive a firmware update to version 77 today.. but it reinstalled easy enough.
Installing on external device /tmp/mnt/sdb1 Creating directory (if not already existing): /tmp/mnt/sdb1/bolemo Creating symlink (if not already existing): /opt/bolemo Creating subdirectories in bolemo: scripts, etc Installing firewall-blocklist files Done! The iprange version offered by this installer are not supported on this device, if you want to install iprange, you need to do it through Entware. Remove install files? [y/n] y Removing install files... Done!
cd /root
ls -l
rm -rf bolemo
@Hello World
while checking aegis status I find I have 1.0.3 installed on my internal drive and 1.1.4 on my external drive.
Dont know how that happened....can you tell me how to clear the internal drive
Thread starter | Title | Forum | Replies | Date |
L | Voxel changed default Firewall setting? | NETGEAR AC Routers and Adapters (Wi-Fi 5) | 3 |
Welcome To SNBForums
