[Alpha] 386.2
Alpha2 but I think it's been like this since 386 it's just now that I actually see it. My provider usually is reliable but this time not.
I'm just going to leave this here:
and maybe
ipv6.he.net <- their free "certification" might be worthwhile (they give you something like 5 tunnels just for successfully completing a level of the "course")
Are there no further update attempts later by watchdog (within 30 seconds or so)? You're only showing 16 seconds of the syslog, so more log info would be helpful.
No later watchdog attempts. I have to chop the bottom as they are all wireless logs and it will be too many to sanitize.
Mar  8 20:08:18 WAN_Connection: WAN(0) link down.
Mar  8 20:08:59 kernel: eth0 (Int switch port: 3) (Logical Port: 3) (phyId: c) Link UP at 1000 mbps full duplex
Mar  8 20:09:03 WAN_Connection: WAN(0) link up.
Mar  8 20:09:03 rc_service: wanduck 1008:notify_rc restart_wan_if 0
Mar  8 20:09:03 custom_script: Running /jffs/scripts/service-event (args: restart wan_if)
Mar  8 20:09:06 lldpd[1017]: removal request for address of 68.xxx.xx.xx%10, but no knowledge of it
Mar  8 20:09:06 wsdd2[3097]: error: wsdd-mcast-v4: wsd_send_soap_msg: send
Mar  8 20:09:06 custom_script: Running /jffs/scripts/nat-start
Mar  8 20:09:06 ntpMerlin: Sleeping for 5s to allow firewall/nat startup to be completed...
Mar  8 20:09:06 custom_script: Running /jffs/scripts/firewall-start (args: eth0)
Mar  8 20:09:06 wan: finish adding multi routes
Mar  8 20:09:06 miniupnpd[3099]: shutting down MiniUPnPd
Mar  8 20:09:06 miniupnpd[20296]: HTTP listening on port 38595
Mar  8 20:09:06 miniupnpd[20296]: Listening for NAT-PMP/PCP traffic on port 5351
Mar  8 20:09:06 start_ddns: update WWW.ASUS.COM update@asus.com, wan_unit 0
Mar  8 20:09:07 inadyn[20320]: In-a-dyn version 2.8.1 -- Dynamic DNS update client.
Mar  8 20:09:07 rc_service: udhcpc 20206:notify_rc start_vpnserver1
Mar  8 20:09:07 custom_script: Running /jffs/scripts/service-event (args: start vpnserver1)
Mar  8 20:09:07 rc_service: udhcpc 20206:notify_rc stop_samba
Mar  8 20:09:07 rc_service: waitting "start_vpnserver1" via udhcpc ...
Mar  8 20:09:07 ovpn-server1[20423]: --cipher is not set. Previous OpenVPN version defaulted to BF-CBC as fallback when cipher negotiation failed in this case. If you need this fallback please add '--data-ciphers-fallback BF-CBC' to your configuration and/or add BF-CBC to --data-ciphers.
Mar  8 20:09:07 ovpn-server1[20423]: OpenVPN 2.5.1 arm-buildroot-linux-gnueabi [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Mar  7 2021
Mar  8 20:09:07 ovpn-server1[20423]: library versions: OpenSSL 1.1.1j  16 Feb 2021, LZO 2.08
Mar  8 20:09:07 ovpn-server1[20430]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mar  8 20:09:07 ovpn-server1[20430]: PLUGIN AUTH-PAM: initialization succeeded (fg)
Mar  8 20:09:07 ovpn-server1[20430]: PLUGIN_INIT: POST /usr/lib/openvpn-plugin-auth-pam.so '[/usr/lib/openvpn-plugin-auth-pam.so] [openvpn]' intercepted=PLUGIN_AUTH_USER_PASS_VERIFY
Mar  8 20:09:07 ovpn-server1[20430]: Diffie-Hellman initialized with 2048 bit key
Mar  8 20:09:07 ovpn-server1[20430]: TUN/TAP device tun21 opened
Mar  8 20:09:07 ovpn-server1[20430]: TUN/TAP TX queue length set to 1000
Mar  8 20:09:07 ovpn-server1[20430]: /usr/sbin/ip link set dev tun21 up mtu 1500
Mar  8 20:09:07 vpnserver1[20433]: PLUGIN AUTH-PAM: BACKGROUND: initialization succeeded
Mar  8 20:09:07 ovpn-server1[20430]: /usr/sbin/ip addr add dev tun21 xx.xx.x.x/24
Mar  8 20:09:07 ovpn-server1[20430]: ovpn-up 1 server tun21 1500 1621 xx.xx.x.x 255.255.255.0 init
Mar  8 20:09:07 ovpn-server1[20430]: Could not determine IPv4/IPv6 protocol. Using AF_INET
Mar  8 20:09:07 ovpn-server1[20430]: Socket Buffers: R=[524288->524288] S=[524288->524288]
Mar  8 20:09:07 ovpn-server1[20430]: UDPv4 link local (bound): [AF_INET][undef]:1194
Mar  8 20:09:07 ovpn-server1[20430]: UDPv4 link remote: [AF_UNSPEC]
Mar  8 20:09:07 ovpn-server1[20430]: MULTI: multi_init called, r=256 v=256
Mar  8 20:09:07 ovpn-server1[20430]: IFCONFIG POOL IPv4: base=xx.xx.x.x size=252
Mar  8 20:09:07 ovpn-server1[20430]: Initialization Sequence Completed
Mar  8 20:09:08 rc_service: udhcpc 20206:notify_rc start_samba
Mar  8 20:09:08 rc_service: waitting "stop_samba" via udhcpc ...
Mar  8 20:09:08 custom_script: Running /jffs/scripts/service-event (args: stop samba)
Mar  8 20:09:08 wsdd2[3097]: Terminated received.
Mar  8 20:09:08 wsdd2[3097]: terminating.
Mar  8 20:09:08 Samba_Server: smb daemon is stopped
Mar  8 20:09:09 dhcp_client: bound 68.xxx.xx.xx/255.255.255.0 via 68.xxx.xx.x for 7200 seconds
Mar  8 20:09:09 custom_script: Running /jffs/scripts/service-event (args: start samba)
Mar  8 20:09:10 custom_config: Appending content of /jffs/configs/dnsmasq.conf.add.
Mar  8 20:09:10 custom_script: Running /jffs/scripts/dnsmasq.postconf (args: /etc/dnsmasq.conf)
Mar  8 20:09:10 Diversion: restarted Dnsmasq to apply settings
Mar  8 20:09:10 (dnsmasq.postconf): Updating /etc/dnsmasq.conf for unbound.....
Mar  8 20:09:10 Samba_Server: daemon is started
Mar  8 20:09:10 wsdd2[20784]: starting.
Mar  8 20:09:11 WAN_Connection: WAN was restored.
Mar  8 20:09:17 inadyn[20320]: Failed resolving hostname xxxxxxxxx.asuscomm.com: Temporary failure in name resolution
Mar  8 20:09:17 inadyn[20320]: Update forced for alias xxxxxxxxx.asuscomm.com, new IP# 68.xxxx.xx.xx
Mar  8 20:09:27 inadyn[20320]: Failed resolving hostname ns1.asuscomm.com: Temporary failure in name resolution
Mar  8 20:09:58 Skynet: [i] Mounting Skynet Web Page As user2.asp
Mar  8 20:21:34 wlceventd: wlceventd_proc_event(486): eth6: Disassoc 06::YY:YY:YY:YY, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8)
Mar  8 20:21:34 hostapd: eth6: STA 06:yy:YY:YY:yy;yy IEEE 802.11: disassociated
Mar  8 20:21:34 hostapd: eth6: STA 06:yy:yy;yy;yy:yy IEEE 802.11: disassociated
Mar  8 20:21:34 wlceventd: wlceventd_proc_event(505): eth6: Auth 06::YY:YY:YY:YY, status: Successful (0)
Mar  8 20:21:34 wlceventd: wlceventd_proc_event(534): eth6: Assoc 06:YY:YY:YY:YY, status: Successful (0)
Mar  8 20:21:34 hostapd: eth6: STA 06:yy:YY:YY:YY IEEE 802.11: associated
Mar  8 20:21:34 kernel: CFG80211-ERROR) wl_cfg80211_change_station : WLC_SCB_AUTHORIZE sta_flags_mask not set
Mar  8 20:21:35 hostapd: eth6: STA 06:YY:YY:YY:YY RADIUS: starting accounting session 7A61B2D4DCA3B90F
Mar  8 20:21:35 hostapd: eth6: STA 06:YY:YY:YY:YY WPA: pairwise key handshake completed (RSN)
Mar  8 20:32:07 hostapd: eth6: STA 54::XX:X:XX:XX WPA: group key handshake completed (RSN)
I was hoping Cake and/or the new GPL would solve the irregular short network disconnects on my MacBook Pro (less than 2 meters away from the router...), but unfortunately not: happened again this morning.
(I have had this with the last few 384 builds and all 386 builds I tried - also after a full reset of nvram/settings)
I'm also surprised by the reported DL/UL speeds: 16/15, where I pay for 250/25 (and most other speed tests report 200/25)
Actually all tests report at most 20 down (instead of 200+) since installing Alpha 2...
(might be coincidence)
I was hoping it would address the buggy protocol messaging when Guest Network is setup without Intranet access, but it is still there on my AX88U. However, it is very stable for me otherwise, so I live with the log spam.
I still seeing a crash on boot (sometimes it takes 2 or 3 tries to successfully boot) in mcpd because of the mcast messages from the google home devices in the house.
Hei,
@RMerlin what is this all about? Weird issues difficult to connect to my wifi.
Mar  9 14:42:49 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Mar  9 14:42:49 kernel: br0: port 1(eth1) entered disabled state
Mar  9 14:42:51 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Mar  9 14:42:51 kernel: br0: port 1(eth1) entered listening state
Mar  9 14:42:53 kernel: br0: port 1(eth1) entered learning state
Mar  9 14:42:55 kernel: br0: topology change detected, propagating
Mar  9 14:42:55 kernel: br0: port 1(eth1) entered forwarding state
Mar  9 14:42:56 dnsmasq-dhcp[1990]: DHCPDISCOVER(br0) 70:26:05:68:x:x
Mar  9 14:42:56 dnsmasq-dhcp[1990]: DHCPOFFER(br0) 192.168.1.247 70:26:05:68:x:x
Mar  9 14:42:56 dnsmasq-dhcp[1990]: DHCPREQUEST(br0) 192.168.1.247 70:26:05:68:x:x
Mar  9 14:42:56 dnsmasq-dhcp[1990]: DHCPACK(br0) 192.168.1.247 70:26:05:68:x:x
Mar  9 14:43:19 kernel: nf_conntrack: automatic helper assignment is deprecated and it will be removed soon. Use the iptables CT target to attach helpers instead.
Mar  9 14:43:26 rc_service: amas_lib 1689:notify_rc restart_firewall
Mar  9 14:43:29 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link DOWN.
Mar  9 14:43:29 kernel: br0: port 1(eth1) entered disabled state
Mar  9 14:43:32 kernel: eth1 (Ext switch port: 0) (Logical Port: 8) Link UP 100 mbps full duplex
Mar  9 14:43:32 kernel: br0: port 1(eth1) entered listening state
Mar  9 14:43:34 kernel: br0: port 1(eth1) entered learning state
Mar  9 14:43:36 kernel: br0: topology change detected, propagating
Mar  9 14:43:36 kernel: br0: port 1(eth1) entered forwarding state
Mar  9 14:43:36 dnsmasq-dhcp[1990]: DHCPDISCOVER(br0) 70:26:05:68:x:x
Mar  9 14:43:36 dnsmasq-dhcp[1990]: DHCPOFFER(br0) 192.168.1.247 70:26:05:68:x:x
Mar  9 14:43:36 dnsmasq-dhcp[1990]: DHCPREQUEST(br0) 192.168.1.247 70:26:05:x:x:x
Mar  9 14:43:36 dnsmasq-dhcp[1990]: DHCPACK(br0) 192.168.1.247 70:26:05:68:x:x
Hei,
These are spanning-tree logs, so every time you connect a network device, the switch port goes through listening and learning states before starting to forward traffic. It's safe to disable spanning tree as long as you don't have a downstream switch connected by redundant links. Frequent spanning-tree port negotiations might be triggered by bad cabling, so make sure everything is fine at that level.
Wow, difference is huge on AC86u:
* Cake QOS enabled: 20 Mbs down / 20 Mbp up
* Cake QOS disabled: 250 Mbs down / 25 Mbs up (which I what I pay for)
(I chose cable and entered 95% of 250/25 in the router settings)
After re-enabling QOS my router lost internet connectivity and I had to reboot.
Wow, if 20 Mbs down / 20 Mbp up is the max throughput available with AC68U which is dual core 1.8Ghz, better forget about Cake QOS on actual and future internet connections
Disable cake from the UI, install CakeQoS from here and try again to see if that works for you. Also, you can display detailed information about your cake settings from CakeQoS menu (In terminal: cake-qos, 3, 3) and share it here or in the script's thread.
I have used that in the past; DL speed was way better back then.
I use Ethernet with VLAN option and Auto on a 200/200 connection (not sure what would be the best yet). A AX88U though.
No bad speeds here
My 2 x RT-AX86U - like 386.2_A2 a LOT ... :D ... everything working well - and appreciate all the security patches that came with latest stock Asus GPL.
I had issues with this back on 386.1 betas, I have wiped and setup fresh since then.
Error : NTP failed to sync after 5 minutes
And then most of my scripts refuse to start (listed in my signature, as well as my router model)
But it has returned with these 2 last builds of the alpha. I have to restore JFFS to recover from it. But even then it is a hit and miss on when and if it solves itself (and then it stays solved until a possible next upgrade).
I've read a few pages here and it does not seem to be mentioned. So I assume it does not happen for many users.
I'll search some more about it and see what I can find... But if someone has an idea, let me know.
I've only swapped to Alpha 2 today after a full reset & reconfigure, but my RT-AX88U main router with 2 RT-AX86U nodes is really flying. It's early days but the performance of CAKE baked-in seems snappier than the old script. Additionally I've been able to remove my USB stick for now.
I'm also using Guest Network 1 on 2.4Ghz with intranet access disabled, distributed to all my mesh nodes, and so far the 1 device I've moved to it seems to be working well and I'm not seeing spurious log entries :)
Something is wrong with your setup. That router should have no trouble hitting 250 Mbps.
