171 commits later, I feel that the 382.1 Alpha code is finally in a usable enough state to provide preview builds for the new RT-AC86U. Note that this isn't as well tested as the usual alpha releases I provide, since I'm not using the RT-AC86U as my primary router yet (too much development work to be done on it).
Make sure you read the included Changelog, for an overview of what changed between Asuswrt-Merlin 380.68 and 382.1, as well as to what was changed from Asus's 382_xxxx code to Asuswrt-Merlin 382.
At this time, only the RT-AC86U is supported. Development hasn't begun yet on any other models, so there is no ETA at all regarding support for other models.
This is still at the alpha stage, so expect a lot of things to still change between now and the first beta release.
For more background on this release, I recommend checking this thread.
Downloads are available in the Test Builds folder.
The Asuswrt-Merlin 382.xxx code is in a new, separate Github repository. The toolchain is also in its own repository.
