L&LD
Part of the Furniture
Hello @AntonK, yes, normally I would for anyone using or relying on the 2.4GHz band, and depending on the router model, the USB drive used, and as you ask, which USB port is used.
If you rely on the 2.4GHz band, it is safer to just put it to USB 2.0 mode.
However, if you want to test if your network/equipment is affected, then try it in USB 3.0 mode, and keep in mind this is the setting you will most likely need to change if you see any issues on your network (specifically on the 2.4GHz band).
I don't rely on the 2.4GHz band and have been using 3.0 mode for a while now.
Note that in my testing, there is no performance difference between the two modes with regards to how amtm and the scripts work (apart from taking slightly longer to install, they work just as quick).
HTH.
HTH.
