amtm amtm - the Asuswrt-Merlin Terminal Menu
Where can I find it and could you be a little more descriptive about the use of this $1 value please? Can you give me a sample command in regards to this please? Thanks bud!
Actually, as I think about it, stopping stubby in services-stop probably makes sense. Shutting down the swapfile, though, makes more sense in unmount.
Here's my unmount script....should give you the idea.....
#!/bin/sh
if [ $1 == "/tmp/mnt/extsys" ] && [ -f "/tmp/mnt/extsys/.swap" ]; then
        # turn off swapfile
        swapoff /mnt/extsys/.swap
fi
exit 0
#!/bin/sh
        # turn off swapfile
fi
exit 0
Thanks for the code but I'm not getting what I have to do with it. I tried replacing a few values with what I thought would work and I illegal operand error I think. Help! Sorry @john9527 I'm useless today.:oops::confused:o_O
This shouldn't require any modification providing your swapfile is "myswap.swp", just copy to /jffs/scripts/unmount and make sure it's executable:
#!/bin/sh
SWP="$(find $1/myswap.swp 2> /dev/null)"
if [ "$SWP" ]; then
        swapoff $1/myswap.swp # cleanly close swap
fi
make it executable with:
# chmod 700 unmount
#!/bin/sh
if [ "$SWP" ]; then
fi
# chmod 700 unmount
This is awesome!! Like you said it works as is. Thanks @cmkelley nice job!!:D:D:D
I have installed both Diversion and Skynet and love both of them. Can I just install AMTM on top or do I have to uninstall them and reinstall thru AMTM. I am a newbie at scripts .
It will detect the existing installed items if they are installed correctly.
Just wondering whether it would be possible to have a disable/enable script in AMTM for Skynet and Diversion. It's something I do occassionally from within each program if I need to see a site or IP address that maybe on their the blacklist. Yes I know I could subsequently whitelist them but I think for the majority of times I do this it's not worth my effort for often multiple whitelist addtions for what is in fact a quick look.
I had both Skynet and Diversion installed and just installed AMTM without any issues. Its working perfectly ok.
@thelonelycoder and @Xentrk, with the recent code consolidation and the addition of HND ASUS routers to the Stubby-Installer-Asuswrt-Merlin are we at the point where the stubby installer might have earned some consideration for inclusion in AMTM?
https://www.snbforums.com/threads/stubby-installer-asuswrt-merlin.49469/page-27#post-458369
I think we are close. I would like to see if we can get a few people to test the updates over the next several days first to validate there are no issues. Then, @thelonelycoder can include it in AMTM.
@Xentrk I sent you a pm.
amtm 1.6 is now available
What's new in amtm v1.6
- Added amtm ASCII Logo
- Improved POSIX compliance (@Adamm, @thelonelycoder)
- General code improvements (@Adamm, @thelonelycoder)
- Auto-truncates Disk check logfile if larger than 1MB (applies only for new installs)
- NEW: Format disk. Formats any ext*, fat, ntfs USB storage disk to ext* filesystem (@Zonkd, , @ColinTaylor, @thelonelycoder)
How to update to amtm v1.6
Use u to update to this latest version.
1.6_beta testers use the following command to update the beta version to amtm v1.6:
curl -s https://raw.githubusercontent.com/decoderman/amtm/master/amtm -o "/jffs/scripts/amtm" && chmod 755 /jffs/scripts/amtm && sh /jffs/scripts/amtm
The beta files on the diversion.ch website have been deleted.
The only thing missing now is the Stubby Installer. Hope it makes the grade soon!;):) Nice work @thelonelycoder !
The last feature to add to Stubby installer is a check to see if the dnscrypt-proxy package from entware is installed as it would be incompatible with Stubby. Once done, the installer can be added to AMTM. Should be soon.
Thank you @Xentrk!
Great work with the format option. An option to tar/restore the usb drive with permissions in tact would be awesome for simple backups and as a compliment to the format option. Adding a diversion backup to that as well would be cool. Then one could easily switch out and use a new usb drive at the snap of a finger or deploy a setup across multiple systems. As well as a factory default.
1 option: backup from one usb drive, to another usb drive
2. backup and manually copy the tar onto a pc, restore to the usb root dir & poof
