Are you running AMTM 2.7?I have a ac86u, latest amtm installed...
Why don't I see a "fd" option in menu? I know it exists, it even works if I run it, but it just isn't shown in main menu...
If you've never run it, then it is hidden as any other non-installed script under the i option.I have a ac86u, latest amtm installed...
Thu Oct 17 10:33:10 PDT 2019 Probing 'hfs' on device /dev/sda
Running disk check v2.4, with command 'fsck_hfs -d -ay' on /dev/sda
/dev/sda: starting
Using cacheBlockSize=32K cacheTotalBlock=1024 cacheSize=32768K.
** Checking HFS Plus volume.
** Checking Extents Overflow file.
** Checking Catalog file.
** Checking Catalog hierarchy.
** Checking Extended Attributes file.
Invalid index key
(8, 333)
** Repairing volume.
** Rechecking volume.
Invalid index key
(8, 333)
Invalid index key
(8, 333)
Invalid index key
(8, 333)
** The volume MacBU could not be repaired after 3 attempts.
volume type is pure HFS+
primary MDB is at block 0 0x00
alternate MDB is at block 0 0x00
primary VHB is at block 2 0x02
alternate VHB is at block 1953458174 0x746f67fe
sector size = 512 0x200
VolumeObject flags = 0x07
total sectors for volume = 1953458176 0x746f6800
total sectors for embedded volume = 0 0x00
Thu Oct 17 10:33:12 PDT 2019 Disk check done on /dev/sda
hfs|hfs+j|hfs+jx) if [ -x /usr/sbin/chkhfs ]; then
CHKCMD="chkhfs -a -f"
elif [ -x /usr/sbin/fsck_hfs ]; then
CHKCMD="fsck_hfs -d -ay"
else
text="Unsupported filesystem '$2' on device $1 - skipping check"
printf "$(date) $text\\n" >> $CHKLOG
logger -t "$TAG" "$text"
fi ;;
My conclusion is the the HFS checking was added with the AMTM disk-check script at some point(?). Maybe this is the macOS Catalina update that broke so many things?It currently doesn't handle Apple's hfs although fsck_hfs is provided in the firmware (under /usr/sbin). [HFS is currently left out solely because I'm not an Apple user and I don't know what string fdisk returns for an HFS filesystem.
Let me check an idea I have to exclude a device or partition.Can I completely disable the disk-check script for a disk, but keep it for others? I ask, since I recently got a MacBook to have iTunes and manage my iPhone, and I am having issues running an addition disk for Time Machine support.
(backstory) I'm really a Linux/Android guy at heart, but age and medical issues have made iOS use mandatory since the apps I need to monitor have poor or no Android support.
I have a 1 Tb drive in the USB 3 slot and a 16Gb flash disk with all SNB utilities in the USB 2 slot. Formatted the 1Tb with the MacBook, and ASUS AC86U had trouble seeing it. Formatted HFS with the Network Map page USB and all ran fine. Then I updated to the new macOS, and all hell broke loose, lost all network connections, router rebooted multiple times. I've disabled Time Machine and removed the drive for now.
disk-check script (I am a code idiot, though I can kind of follow, I have minimal understanding of the full effects). This appear to me that it will skip the HFS disks(?)Code:Thu Oct 17 10:33:10 PDT 2019 Probing 'hfs' on device /dev/sda Running disk check v2.4, with command 'fsck_hfs -d -ay' on /dev/sda /dev/sda: starting Using cacheBlockSize=32K cacheTotalBlock=1024 cacheSize=32768K. ** Checking HFS Plus volume. ** Checking Extents Overflow file. ** Checking Catalog file. ** Checking Catalog hierarchy. ** Checking Extended Attributes file. Invalid index key (8, 333) ** Repairing volume. ** Rechecking volume. ** Checking HFS Plus volume. ** Checking Extents Overflow file. ** Checking Catalog file. ** Checking Catalog hierarchy. ** Checking Extended Attributes file. Invalid index key (8, 333) ** Repairing volume. ** Rechecking volume. ** Checking HFS Plus volume. ** Checking Extents Overflow file. ** Checking Catalog file. ** Checking Catalog hierarchy. ** Checking Extended Attributes file. Invalid index key (8, 333) ** Repairing volume. ** Rechecking volume. ** Checking HFS Plus volume. ** Checking Extents Overflow file. ** Checking Catalog file. ** Checking Catalog hierarchy. ** Checking Extended Attributes file. Invalid index key (8, 333) ** The volume MacBU could not be repaired after 3 attempts. volume type is pure HFS primary MDB is at block 0 0x00 alternate MDB is at block 0 0x00 primary VHB is at block 2 0x02 alternate VHB is at block 1953458174 0x746f67fe sector size = 512 0x200 VolumeObject flags = 0x07 total sectors for volume = 1953458176 0x746f6800 total sectors for embedded volume = 0 0x00 Thu Oct 17 10:33:12 PDT 2019 Disk check done on /dev/sda
I see this from the original script, found by checking the Diversion website, AMTM page links back here.Code:hfs|hfs j|hfs jx) if [ -x /usr/sbin/chkhfs ]; then CHKCMD="chkhfs -a -f" elif [ -x /usr/sbin/fsck_hfs ]; then CHKCMD="fsck_hfs -d -ay" else text="Unsupported filesystem '$2' on device $1 - skipping check" printf "$(date) $text\\n" >> $CHKLOG logger -t "$TAG" "$text" fi ;;
https://github.com/RMerl/asuswrt-merlin/wiki/USB-Disk-Check-at-Boot
Bottom line is I lost all the data on that 1Tb drive attached to the AC86U, macOS Time Machine automatic backups, iPhone archives before software updates. Because I am fanatical about backing up every phone, computer, etc. that I can, I really want to resolve this. At least be able to check the USB flash drive that is EXT4 on reboots.
I'm sorry to hear that. But consider this unfortunate incident as helping the advancement of amtmBottom line is I lost all the data on that 1Tb drive attached to the AC86U, macOS Time Machine automatic backups, iPhone archives before software updates. Because I am fanatical about backing up every phone, computer, etc. that I can, I really want to resolve this. At least be able to check the USB flash drive that is EXT4 on reboots.
/dev/sdb3 with vfat file system exluded from check (UUID="5CFD-3EB7")
Sat Oct 19 18:38:09 CEST 2019 Probing 'ntfs' on device /dev/sdb1
Running disk check v2.5, with command 'ntfsck -a' on /dev/sdb1
ntfsck 3017.7.18.13
Checking NTFS Superblock ...
Device name : /dev/sdb1
NTFS volume version: 3.1
Cluster size : 4096 bytes
Current volume size: 5660193280 bytes (5661 MB)
0.00 percent completed
100.00 percent completed
Done NTFS checking and repair on device '/dev/sdb1'.
Syncing device ...
Sat Oct 19 18:38:10 CEST 2019 Disk check done on /dev/sdb1
/dev/sdb2 with ext4 file system exluded from check (UUID="e13e3fe8-7dea-497a-832b-a86f5b959e19")
I'm not sure that this will solve your problem even if the disk check excludes the drive. From the log file you posted the fundamental problem appears to be that the disk was corrupted. The disk check tried to fix it but couldn't, the same error persisted. There is no evidence (so far) that the corruption was caused by the disk check. Also, whether the disk check runs or not has no bearing on whether or not the router mounts the disk, that's a completely separate process.Bottom line is I lost all the data on that 1Tb drive attached to the AC86U, macOS Time Machine automatic backups, iPhone archives before software updates. Because I am fanatical about backing up every phone, computer, etc. that I can, I really want to resolve this. At least be able to check the USB flash drive that is EXT4 on reboots.
I didn't even read the error log, glad we have that verbose output of the check.I'm not sure that this will solve your problem even if the disk check excludes the drive. From the log file you posted the fundamental problem appears to be that the disk was corrupted. The disk check tried to fix it but couldn't, the same error persisted. There is no evidence (so far) that the corruption was caused by the disk check. Also, whether the disk check runs or not has no bearing on whether or not the router mounts the disk, that's a completely separate process.
Yes, it's definitely an option worth having. I think some people have commented in the past that they'd prefer not to have to wait for their very large disks to be checked. They'd prefer to have the router boot up faster and accept any potential consequences.I didn't even read the error log, glad we have that verbose output of the check.
The exclusion code might still be of use for some so I'll build it in.
I just tested it with a device with three partitions (ntfs, vfat and ext4), vfat and ext4 are excluded.
I'm using the UUID for partitions to exclude which is unique.
Code:/dev/sdb3 with vfat file system exluded from check (UUID="5CFD-3EB7") Sat Oct 19 18:38:09 CEST 2019 Probing 'ntfs' on device /dev/sdb1 Running disk check v2.5, with command 'ntfsck -a' on /dev/sdb1 ntfsck 3017.7.18.13 Checking NTFS Superblock ... Device name : /dev/sdb1 NTFS volume version: 3.1 Cluster size : 4096 bytes Current volume size: 5660193280 bytes (5661 MB) 0.00 percent completed 100.00 percent completed 0.00 percent completed 100.00 percent completed 0.00 percent completed 100.00 percent completed Done NTFS checking and repair on device '/dev/sdb1'. Syncing device ... Sat Oct 19 18:38:10 CEST 2019 Disk check done on /dev/sdb1 /dev/sdb2 with ext4 file system exluded from check (UUID="e13e3fe8-7dea-497a-832b-a86f5b959e19")
Well, after more investigation, crashing my AC86U a few more timesI didn't even read the error log, glad we have that verbose output of the check.
/dev/sda3 on /tmp/mnt/sda3 type thfsplus (rw,nodev,relatime,umask=0000,uid=0,gid=0,nls=utf8,readahead=1M)
Any particular reason why you’re using Apple partition map?
The Macbook is new to me. I know it is based on Linux
Nope, closing my eyes and throwing darts at the board.![]()
I'd have to cut down the options.Love amtm, and hearty thanks to all of it's contributors - takes Merlin to another level. That said, with hat in hand, could I humbly suggest an upgrade to the amtm chron job reboot section that would allow for some more complex constructs. Maybe a text version of something like the:
https://crontabgenerator.org
This would allow a little more flexibility in the reboot schedule while keeping the present simplicity for the user. In my case I was looking for a way to reboot every other day. The closest I can get appears to be,
45 3 1-31/2 * *
which is acceptable. Thanks for considering it.
Odd or Even days, once or twice a month. Or else this code gets out of hand.
@all and @ElmerLove amtm, and hearty thanks to all of it's contributors - takes Merlin to another level. That said, with hat in hand, could I humbly suggest an upgrade to the amtm chron job reboot section that would allow for some more complex constructs. Maybe a text version of something like the:
45 3 1-31/2 * *
Welcome To SNBForums
