Butterfly Bones
If your sig is correct, you have a really, really old firmware version that had a bug for years. You might want to update since it was fixed recently by ASUS.Here's another Yea to keep the thread the way it is.
But hopefully it's not against that threading policy to make 2 suggestions:
1. I would vote for a version change every time there is a change, no matter how small. As a guy who used to work in an environment where versions were religiously changed, it really does make it easier for others to know when something is different.
2. You have a nice feature of scheduling a router reboot using the rs command. I used it but just now wanted to see how long the GUI would stay working without a weekly reboot after I disabled AIProtect. Btw, I found that rs only sometimes works. When it fails, the router goes to sleep that requires manual intervention to get going again. Anyway, when I disabled rs, and the amtm menu repainted, the rs command was gone. I expect that in 2 months when I want to add it back in, I will have forgotten that command, and will need to search the thread to find it. Maybe you could present the rs option in a way that says it is disabled, or greyed out, or ??. That way I can at least find the command when I need it. Also, are there any other commands like that, that if you are not using it, just disappears from the menu?
Thanks,
https://www.snbforums.com/threads/ac86u-sometimes-powers-completely-off-during-reboot.48296/
Check out the I nstall choice in the menu in AMTM. That is what Colin Taylor is showing you above. This is from the image in post #1 of this thread.
i install scripts or tools
