amtm amtm - the Asuswrt-Merlin Terminal Menu
Am I the only one?
Sent from my SM-G965F using Tapatalk
Happened to me. I restored a backup of the router from before the last update, then was able to successfully run the update on AMTM.
I'll give a try, thanks.
I've just updated firmware from 384.15 to .16
I'm finding now different strange things. If that doesn't work I'll do a hard reset and start from scratch
Hmm... there has been entware update today and I cannot update one of the packages... it gets downloaded but fails to get replaced
EDIT:
opkg upgrade gave more insight:
Upgrading libncursesw on root from 6.1-5 to 6.2-1...
Downloading http://bin.entware.net/aarch64-k3.10/libncursesw_6.2-1_aarch64-3.10.ipk
Collected errors:
 * check_data_file_clashes: Package libncursesw wants to install file /opt/lib/libform.so.6
        But that file is already provided by package  * libncurses
 * check_data_file_clashes: Package libncursesw wants to install file /opt/lib/libmenu.so.6
 * check_data_file_clashes: Package libncursesw wants to install file /opt/lib/libncurses.so.6
 * check_data_file_clashes: Package libncursesw wants to install file /opt/lib/libpanel.so.6
EDIT:
Collected errors:
I've had the same problem.
This resolves the problem:
opkg install --force-reinstall libncursesw
Not sure if this has already been fixed, but I just ran the update and it went fine with no errors.
Well running the command broke my spdmerlin and conmon :P
***@router:/tmp/home/root# /jffs/scripts/spdmerlin generate
spdMerlin: Starting speedtest using *** for WAN interface
   Speedtest by Ookla
     Server: ***
        ISP: ***
    Latency:     0.96 ms   (0.01 ms jitter)
   Download:   374.79 Mbps (data used: 169.4 MB)
     Upload:   437.89 Mbps (data used: 720.1 MB)
Packet Loss:     0.0%
 Result URL: ***
/opt/bin/sqlite3: error while loading shared libraries: libncursesw.so.6: wrong ELF class: ELFCLASS32
sed: /jffs/addons/spdmerlin.d/csv/Downloaddaily_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Downloaddaily_WAN.tmp: No such file or directory
awk: cmd. line:1: Division by zero
sed: /jffs/addons/spdmerlin.d/csv/Downloadweekly_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Downloadweekly_WAN.tmp: No such file or directory
sed: /jffs/addons/spdmerlin.d/csv/Downloadmonthly_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Downloadmonthly_WAN.tmp: No such file or directory
sed: /jffs/addons/spdmerlin.d/csv/Uploaddaily_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Uploaddaily_WAN.tmp: No such file or directory
sed: /jffs/addons/spdmerlin.d/csv/Uploadweekly_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Uploadweekly_WAN.tmp: No such file or directory
sed: /jffs/addons/spdmerlin.d/csv/Uploadmonthly_WAN.tmp: No such file or directory
head: /jffs/addons/spdmerlin.d/csv/Uploadmonthly_WAN.tmp: No such file or directory
Which I have fixed by running
*no >>>w<<< at the end ;)
The unbound daemon dosent upgrade through amtm - anyone else have this issue?
 ep manage   Entware packages    -> upd avail
- unbound-daemon         1.9.6-1   -> 1.10.0-2
Installing libunbound-light (1.10.0-2) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/libunbound-light_1.10.0-2_arm        v7-2.6.ipk
Collected errors:
 * check_data_file_clashes: Package libunbound-light wants to install file /opt/lib/libunbound.so.8
        But that file is already provided by package  * libunbound
Also tried this to no avail - except now since its deleted the old verion of unbound-daemon and it cant install the new version I am left with a screwed Unbound installation with NO daemon
HELP PLEASE!!
joescian@RT-AC5300-0680:/jffs/scripts# opkg install --force-reinstall unbound-daemon
Removing package unbound-daemon from root...
Installing unbound-daemon (1.10.0-2) to root...
Downloading http://bin.entware.net/armv7sf-k2.6/unbound-daemon_1.10.0-2_armv7-2.6.ipk
Downloading http://bin.entware.net/armv7sf-k2.6/libunbound-light_1.10.0-2_armv7-2.6.ipk
Collected errors:
 * opkg_install_cmd: Cannot install package unbound-daemon.
I had htop installed it has a dependancy on libncurses that was causing problems. I removed htop and everything is OK. Will have to wait for entware to sort out the dependancy before installing htop again.
I'm on ATT 1000 Fiber with 384.16 and have enabled IPV6 as native, no other ipv6 settings changed. the ipv6 test pages on the web show all green, yet downloading amtm packages via ipv6 times out or is really slow.
Any suggestions?
@busch09 what do you have for your WAN DNS server settings?
Try testing with 'Manual' and 1.1.1.1 and 1.0.0.1 or, if those are already in place, try using 'Automatic' to use your ISP's defaults. Or, of course, try with Quad9 DNS IP's too. :)
I had to re-create a swap file as my USB stick died on me and since I mainly have 1GB sticks around the 1GB option does not work. Before i had 512MB set up which I think to remember was available as an option within AMTM.
Could we bring back that option or better have a manual entry in MB's to solve this?
I'd say some people will still have 1 or 2GB sticks lying around where the 1/2GB swap option will be too big! I had to manually create my swap file.
I will not bring back that option in amtm. The minimum 1 GB swap file eliminates errors in connection with Skynet, which should be installed on all routers anyway IMHO.
I will not bring nack that option in amtm. The minimum 1 GB swap file eliminates errors in connection with Skynet, which should be installed on all routers anyway IMHO.
@markusd1984 I agree that 1gb should be the minimum. USB drives are cheap. But if you are hell bent on a swap file less than 1gb, google tells me;
https://linuxize.com/post/create-a-linux-swap-file/
You would have to use the dd command though. I have not tested this, so do so at your own risk.
hello
i wanted to get your advise regarding the reboot scheduler. it is not working for me at all. the router doesnt reboot on specified times. for example, as of today, it shouldve reset 2 days ago
how can i troubleshoot this?
thanks
