hadesflames
I'm assuming there's no real difference between antennas from one antenna to another aside from one antenna perhaps being more powerful than another. Right?
Mostly curious because I saw a spec page on a wifi adapter indicate that the antenna is specifically a wifi 6E antenna which I thought was weird that it would even list this. So now I'm wondering if that's just marketing or if there's any actual difference technically between a wifi 6 vs a wifi 6E atenna. I know 6E adds the 6ghz radio but does that need to be supported in the antenna itself as well? And would there be any difference between a wifi 6E antenna vs a wifi 7 antenna then for example if that's the case?
