ASUS ExpertWiFi EBG15
tiddlywink
Wired Router
ASUS​
ExpertWiFi​
EBG15​
$89.00​
5 Gigabit Ports​
1 x WAN Port, 4 x LAN Ports (2 x WAN/LAN Ports)​
ASUS​
ExpertWiFi​
EBG19P​
$180+​
9 Gigabit Ports​
1 x WAN Port, 8 x LAN Ports (2 x WAN/LAN Ports) with PoE+ - 123W power budget​
Wireless Routers
ASUS​
ExpertWiFi​
EBR63​
$149.00​
WiFi 6​
AX3000, 2.4GHz AX: 2x2 + 5GHz AX: 2x2​
ASUS​
ExpertWiFi​
EBM68​
$299.00​
WiFi 6​
AX7800, 2.4GHz AX:2X2+5GHz-1:2X2+5GHz-2:4X4​
Wireless PoE Access Point
ASUS​
ExpertWiFi​
EBA63​
$129.00​
WiFi 6​
1x PoE LAN port - AX3000, 2.4GHz AX:2x2+5GHz AX:2x2​
Managed PoE Switch
ASUS​
ExpertWiFi​
EBP15​
$89.00​
Managed Switch​
1 x LAN port + 4 PoE+ Port - 60W power budget​
All vlan aware and AiMesh compatible.
Firmware: Version 3.0.0.6
Setup
expertwifi.net or asusrouter.com or default 192.168.50.1
"Asus ExpertWifi" app via google play store or apple store can also config this via BT (didn't test this).
AiMesh
  • 100% working
VLAN aware AiMesh node required for VLAN over SSID
All AiMesh bands get put under one, single SSID. You can hide this SSID, but not disable it.
Five SSID's possible.
VLAN
A. Create VLAN without DHCP
1. Settings -> Lan -> Vlan -> Profile = create VLAN​
2. "Self-defined network" -> select vlan -> advanced settings = choose the network here​
B. Create VLAN with DHCP
1. "Self-defined network" -> Customized Network ->​
  • WiFi Band = None
  • "SSID" = name for VLAN ID
  • Intranet - access or deny
  • Same subnet or not
2. "Self-defined network" -> select vlan -> advanced settings = choose the network here.​
  • Change VLAN ID and network to what you want
Trend Micro
Declining is possible and has no affect on usage.
ExpertWiFi Demo WebUI
EBG Router/Firewall/Controller + EBP Switch + EBA Access Point: Link 1
EBM Router/Firewall/Controller + EBR Access Point: Link 2
Welcome to the forums @tiddlywink.
Buyer beware (always). Buy, test, and evaluate well within the return period.
Myself? I wouldn't buy this if the decimal point was moved over to the left two times.
Bluetooth setup for a wired router? Give me a break.
This sounds like fairie dust snake oil at its finest. I sincerely hope it fails hard, so that real products are produced instead.
There is also EBG19P model with 8x PoE ports and 123W power budget.
I see it as another proof 3.0.0.6 firmware can actually run on "older hardware" perhaps down to RT-AX58U V2* and many current models will be killed for marketing reasons. The other concern is once again included "free" Trend Micro service with data sharing agreement. This may not go well on a business market.
* - the single PoE AP Asus currently have is most likely BCM6756 based with built-in 2x2 radios. Runs Asuswrt 3.0.0.6, AiMesh node.
BT is just for phone app setup and maybe management.
From the amazon.com page: "up to five SSID." I assume this means a choice of five wireless SSID and/or VLAN. Shouldn't that also be "Software-defined networking" not "self-defined network?"
PoE 8 port is same SoC.
Went in stock on Amazon. Bought one for testing and will be here this week.
I have such a low bar for VLAN that this should work. If not, I will return and force myself to move to tplink which I am trying to avoid.
It seems a very odd direction to be going in. Bluetooth setup, WiFi via additional APs only, no 2.5Gbps or 10Gbps port(s). Very odd!
I'd also wonder with the 8+1 port PoE version does it have a switched power supply?
Got it.
expertwifi.net and asusrouter.com both get you to the settings. 192.168.50.1
Must agree to EULA and Privacy policy to use. :mad:
Firmware update via browser to latest: 3.0.0.6.102_44136. Popups are a thing after firmware update if it changes.
59% memory usage; no idea if good or bad.
Bugs
Fixed
Not a bug
AImesh
Works
AP
Works
VLAN
Need more time to test
  • Screenshot 2024-04-13 at 15-17-27 ASUS Wired Router ExpertWiFi EBG15 - Quick Internet Setup.png
  • Screenshot 2024-04-13 at 15-18-01 ASUS Wired Router ExpertWiFi EBG15 - Quick Internet Setup.png
Wireless setting shouldn't be there as this doesn't have wireless
By the way, this router has to have basic wireless settings. As per description it can be used as AiMesh main unit. AiMesh nodes don't have own WebGUI. 💡
What about Trend Micro?
Did not agree and it works fine without. AIProtection and Traffic Analyzer are empty.
You are right about the wireless. I just expected that to be "off" until aimesh was activated. There is an "AiMesh Node" as a choice for operating mode.
VLAN
Note: don't have aimesh working so this is strictly about wired and all I have available are dumb switches/dumb poe switches.
Settings -> Lan -> Vlan -> Profile = create VLAN without DHCP
My experience
Port4 -> VLAN 100. Some devices showed up correctly. Some just didn't want to move. My very low bar appears to be have been too high. Had another bug where a static route was incorrectly labeled as DHCP in the client list.
Annoyances:
Absolutely any changes requires a complete restart of network and re-login.
GUI will beachball/freeze sometimes after applying settings.
In this case the router will work as a simple Ethernet switch. Why would someone pay $90 for a 5-port Gigabit switch - I don't know.
AImesh working. :eek::D
No clue what was preventing this. Don't use dumb switches (tried with trendnet, buffalo, and TPlink), try different cables, use the shortest cables you can find, connect directly to EBG15.
ac68u's + EBG15
  1. Hold WPS button
  2. Plugin in power
  3. Wait for power led to flash
  4. Release
  5. **wait for aimesh node to fully boot up ** (i.e. default asus SSID's fully show up as available + 3-4 minutes)
  6. Click Add AiMesh Node in EBG15. Should instantly find it. Any delays = likely fail = restart at #1
  7. Takes at least 5 minutes to add.
If new ssid's show up; but fails to add = restart at #1
Another bug in client list:
aimesh nodes only = ethernet, wireless bands are tagged properly
AP's = wireless clients can be labeled "ethernet" despite being wireless
(Note: Keystone jack or switch port is bad on one aimesh node shown in my attachment)
Currently picking out new smart switches to hopefully get vlan working.
(Mods/Admin moved this to wireless, so I guess I will stop posting at the other thread.)
ExpertWiFi Demo WebUI is up on asus.com Links in first post.
EBR63 works as a node.
EBM68 has way more advanced settings. "Smart Connect?"
It appears you can add/remove VLAN's/SSID's from specific AiMesh nodes.
According to the demo, up to 8 SSID's can be created, not just five.
Does anyone know what "Security Upgrade" is? Is that just trend micro?
Auto Firmware Upgrade
Automatically install system updates overnight after they have been downloaded. Some upgrades addressing important security issues or meeting legal/regulatory requirements will still be downloaded and installed automatically, even if \"Auto Firmware Upgrade\" is turned off.
Security Upgrade
Security upgrade incorporates security measures that continuously update its security file and scans to protect against malware, malicious scripts, and emerging threats in order to secure the router and ensure system stability. Some upgrades addressing important security issues or meeting legal/regulatory requirements will still be downloaded and installed automatically, even if “Security Upgrade” is turned off.
  • Screenshot 2024-04-19 at 13-26-39 ASUS Wireless Router ExpertWiFi EBM68.png
  • Screenshot 2024-04-19 at 13-32-04 ASUS Wireless Router ExpertWiFi EBM68.png
The same ASD that bricked millions of Asus routers not long ago. Users had to reset to defaults or delete the bad file over SSH.
This "business" router won't fly with forced firmware updates, automatic security updates with bad history and data sharing to 3rd party company.
Read the messages on the screen carefully. If Asus decides so you get the updates anyway. The same with their consumer products.
