Release ASUS GT-AX6000 Firmware version 3.0.0.6.102_34810 (2024/11/11)
When setting up a HTTPS connection in the adminstration/system settings, setting to both and 8443, than installing the certificate into Edge the certificate only works 1 day, the next day i get your connection isnt private.
Asus GT-AX6000
MS Edge version 131.0.2903.112
It's much smoother if you use a "Lets Encrypt" certificate, though my setup is a little eclectic, so hopefully @Ripshod or one of the other regulars who have this working with more normal settings, can point you in the right direction!
To be honest, though I have it working there's really no need to secure a local connection to your own router. Just add exceptions in your browser.
The way I did it was to use the same FQDN I use for NO-IP DDNS, opting to use the let's encrypt certificate. So I use the same domain to access my router from the LAN as I'd use to access my network from the internet, along with the certificate that's automatically provided. It's really quite simple.
Are
Do you have any instructions/config info posted? This has always been a mystery to me how an internet domain can be used for both local and external.
There's only two places for the necessary settings - ddns and lan
If you need further help start a new thread - let this one get back on track 😁
This gets you from A to B, but sort of left-hand side driving in networking and you may get corrected for doing unconventional wrong in general things. :)
Why does the certificate last 2 days instead of until 2045?
Are you using private browser windows? Did you manually install the certificate or use the browser's prompt to 'add it'?
That's just how it looks when you view the certificate directly - quite normal!
I now installed the certificate using the browser prompt.
Installing the certificate with certificates management in Edge fixed the problem.
Today the problem with the certificate is back.
Hi all, is anyone having issues with the Parental Controls with the new firmware (3.0.0.6.102_34810)? The Time Scheduling or even the manual block does not seem to work.
i use manual block many time (in app) and work ok.
Hello there, just flashed this firmware, wondering when I'm setting the VPN-wiregaurd, you can see the clients are using the IP of the VPN, but the DNS. server its still using what I have set in the WAN page (DoT)
anyone else having these issues or there another setting I need to set
