Is 5517 for the Ac68u or the N66u?? I thought 5047 was the latest release for the 68U. Can someone clarify this.
found this...
http://dnlongen.blogspot.com/2014/04/CVE-2014-2719-Asus-RT-Password-Disclosure.html
which implies .5517 is coming but hasn't been released yet
Anyone else getting bad Wi-Fi slowdowns with 5047?
A new bug appear in the latest version of the firmware. The router doesn't Wake up a wifi printer. This was not a problem on earliest version. Example, if a want to print a document on iPad, I get the message that there is no printer available. This happen if I have not use the printer for a long time (4 hour). Somebody else have this problem?
I updated to this firmware and tried setting up port forward, but it fails. I trying to setup the port forward for my ceton my media center app which worked flawlessly when I had an older netgear router.
Steps taken
1. Assigned PC in question here ip 192.168.2.181
2. logged into router and accessed port forward page.
3. enabled port forwarding
4. Created port forward entry for local port 5832 (the app uses this port) on ip 192.168.2.181 for TCP traffic.
5. After entering the rule I hit apply and let the router update.
6. After update I test the port forward on the app and it fails everytime.
I'm frustrated as I've done port forwards before and can't seem to get it to work with this router.... Any help would be greatly appreciated.
I had the same problem with port forwarding ceasing to function after updating to this version. I even called tech support but the guy at the other barely knew anything. He said (and I quote) "maybe the new firmware does not support port forwarding". I said I will figure it out on my own and hung up on him.
I then proceeded to delete the existing port forwards in place, disabled port forwarding, re-enabled it, power cycled the router, then setup the port forwards again, and voila, it appeared to fix the issues.
Question to people having issues with port forwarding.
Why aren't you using UPnP?
I have UPnP enabled and I have no issues with any ports.
If its for security reasons, then I only have one simple comment. If someone wants to hack your network, then they will do so and nothing will stop them.
Few years back someone tried to hack me, but they ended up freezing my router. A simple power cycling the router and everything was back to normal.
Having said that, I can't get my FTP port forwards to work after the update even though I did manage remote desktop to work. This sucks, I'm really tempted to flash DD-WRT to see if it will rid some of these headaches.
Tried to set up the ASUS AC68U with Windows Server Essentials but could not get the server to set up Anywhere Access properly. Tried it with UPnP enabled without ports 80 and 443 forwarded, as well as with UPnP disabled and ports 80 and 443 forwarded. Theoretically, all I should have had to do was forward 443-HTTPS. (I used Merlin's firmware version that removed the restriction on forwarding ports 1-1024.)
Has anyone attempted to use the AC68 with a WSE box with outside access working properly? Any hints would be appreciated. Thank you.
Welcome To SNBForums
