I still wonder why some report a high CPU load with firmware 3.0.0.4.385.20253 and me and for sure many others do not observe a high CPU load.
Maybe we can determine what feature is causing the high CPU load.
The only issue for me is why the new Asus Healing System needs daily updated signature files, and what does it really do?
See this post
https://www.snbforums.com/threads/a...-version-3-0-0-4-385-20253.62620/#post-561787
My situation is:
RT-AC68U (hardware version A2).
RT-AC66U B1 (hardware version B2)
Revert to factory defaults some moment after the upgrade to 3.0.0.4.385.20253.
Did this.
Manual configured the router, as follows from default:
Advanced Settings - Wireless - General - 2.4 GHz
Left all at default after reset
Channel bandwidth: 20 MHz
Control Channel: 1
Advanced Settings - Wireless - WPS
Enable WPS: OFF
Also did this.
Advanced Settings - Wireless - Professional - 5 GHz
Airtime Fairness: Disable
Universal Beamforming: Disable
Advanced Settings - LAN - LAN IP
Host Name: [another name]
Advanced Settings - WAN - Internet Connection
Enable UPnP: No
Also did this
Advanced Settings - Administration - System
USB Mode: USB 2.0
Left all at default after reset which is USB 3.0. Nothing hooked up to USB.
Time Zone: (GMT+1:00) Amsterdam, Berlin, Bern (GMT -7:00)
Arizona (no DST here)
DST time zone changes starts: month = 3, weekday = 5th Sun, 2 hours
DST time zone changes ends: month = 10, weekday = 5th Sun, 3 hours
USB application - Servers Center - Media Server
Not used.
Enable UPnP Media Server: OFF
Guest Network
None setup
Set one 2.4GHz guest network.
