ASUS RT-AC86U - 4th May - New Firmware version 3.0.0.4.384_81858 (04.05.2020)
Laggards! :D
OE
installed it right away
works great
transmitter power has not changed
the number of regions has not changed
this can not but rejoice, the most powerful region with 30dBm works best
[QUOTE = "K-2SO, post: 582764, member: 69087"] Изменение региона - это ваш конкретный вариант маршрутизатора. У многих пользователей его нет. [/ QUOTE]
Я меняю регион на любом устройстве ASUS на базе процессора Broadcom
но вы не можете обсуждать это на этом форуме, поэтому есть другие ресурсы, где это обсуждается, а также как правильно настроить данные устройства для получения максимальной производительности.
N18, N66, AC66, AC68, AC86, AC87, AC88, AC3100, AC3200, AC5300
AX56, AX58, AX88, AX92, AX95, AX1000
Подготовка смены региона для устройства, не включенного в список, занимает около часа
Повторюсь, я не поддерживаю устройства на MTK и Realtek, только Broadcom
They both say you can use use the WPS button
Yes. The procedure is a little different on different models.
which YOU said before only clears nvram.
Turns out it's a jffs partition related bug with HND routers. This thread describes the issue:
https://www.snbforums.com/threads/factory-reset-still-shows-device-list-and-dhcp-table.63992/
My router recovered with Reset button only. The other person had to perform invasive surgery. :oops:
granted this comment is a bit of an aside but i'm amazed at how quickly K-2SO has achieved "senior" status after just joining in late april.
perhaps he or she may be willing to share their credentials or background that resulted in this achievement? welcome to the board.
The number of posts in a defined period of time. :)
Data company, data center, management, COVID-19, clients shut down. o_O
Business equipment we run is not the main focus of this forum. Helping with what I know about Asus routers. Learning new things around latest models. Keeping myself busy. I only monitor servers online now. Things will change end of May.
Well...i could post endlesly and also move up the ranks with my 20yrs of IT experience...but i still have my day job :)
I have no talents whatsoever but one can always learn and this forum is a fantastic source of knowledge, I learned enough to be dangerous :)
Aargh... why is this captcha coming so often on LAN? :mad:
I can't catch the logic when it is popping up and why. Random?
PS. This post contained off topic. Back on track better.
Random...no lógic...i havent seen it popup on my router after my last reboot 6 days ago.
