Merlin: Any idea how to get AX88U link aggregation working on Rogers ISP with the Hitron modem?
No.
Hi everyone,
I am updating my network configuration at home. I'm move from an assus n66u to the rt-ax88. I want to increase the speed of my openvpn like. Before i was downloading at 1 MB/s, and with my new router i am reaching 10MB/s ... it is probably my limit , as with no encroprytion or VPN i go 10 MB/s at max. So i am very happy to that.
But here is my original goal of my post. I'd like to report issue about the wireless stability of the router asus rt-ax88. I have a very good understanding of the issue, as i have tried many many way to get ride of it.
First, i describe the issue :
- the Wifi 5ghz or 2.4Ghz doesn't work at all ( every setting are ok, trust me) .
- the LED of 2.4 Ghz doesn't light up at boot. Only the 5Ghz is ON ... but no wifi network at all.
Here are my negative observation :
- i got this issue after installing the Merlin Firmware , despite i follow the instruction. ( * note: this issue is note related to Merlin FW... but Hardware or assus source )
- i got this issue even after rolling back to Asus official Firmware , with rescue mode , and the firmware restoration tools. =>
- i got this issue while network cable are plug in, or not.
Here is my positive observation, and how the issue got resolved :
- You need to switch ON/OFF with the button, at least 4 or 5 time the router
- This work, whatever the firmware version is : Official or Merlin. <===
- When the status is OK ( all light of 2.4 Ghz and 5 Ghz are on) => A reboot from the webinterface won't make the issue appears again.
- Only switching ON/OFF will make the issue appears...(then you have to restart the router several time).... and disappears after 4-5 cycle.
The cycle OFF/ON to repeat :
- Use the button switch OFF/ON
- OFF for 10 sec
- ON and wait for the LED to light on ( i wait for the Power LED blink 3 times before going steady ).
- OFF again
- Repeat until LED 2.4 Ghz and 5 Ghz are ON together , after the power ON ... then leave the router.
I tried this many time ... and it is repeatable ( i am not just sure about the 4 or 5 times.
In conclusion : Don't give up with Merlin Firmware, this issue is also on official release. And restart router many time solve the issue.
I am using now Merlin Firmware, because i know it is the same on Assus Official Firmware, and because i have a resolution procedure.
PS: I think i'am on the same situation of WifiSeeder. I won't return the router, because i can't. Otherwise, i will do.
I have had less trouble with the RT-AX88U than I did with:Glad I didn't jump on this like I did with the AC88U and get jerked around with false advertisement and glitched firmware. Good luck AX88U beta testers.
Just picked up a AX88U. I have a Intel/Killer 1550/9260 in my laptop. Sitting 7 feet from router. Im trying to achieve gigabit speeds without going hardwired. I had a Ubiquiti AC-HD before the AX88U and I couldnt get and good speed. Using the AX88 @ 160 Im getting 580 down and 860 up when testing with speedtest.net. I have FIOS gigabit wan. In order to get a 1.7 connection, I have to manually select 36,40,44,48 channels. No DFS channels work above 866MBit. Anyone have any tips on getting good down speeds that have a 9260 and the AX88u? I dont have any QOS or AI whatever enabled.
Already using ASUS Merlin FW (Latest), also removed all killer software and using intels drivers, Alienware 17 R5 always plugged in with performance power setting. i9-8950HK, 32GB RAM, GTX1080What firmware are you using? Is it the as-shipped firmware or did you upgrade? If you upgraded, I would recommend you perform a full reset to factory defaults. I would further recommend RMerlin's firmware too.
I would remove the 'killer' software from your laptop too for best performance. I would also suggest you test from further than 7' from the router.
Use multiple test sites. For 'max' speeds, fast.com seems to be the quickest/easiest to use. dslreports.com/speedtest gives the most accurate actual world speeds. Use them all and get a feel for which reports what.
When the laptop is being used for the tests, is it in Performance mode (or plugged into AC power)? This can make a difference depending on how the manufacturer feels about saving battery life or not.
To properly test, put the laptop at least a 15' away from the router in the same room at approximately the same 'eye level' with each other and pay attention to the orientation of the laptop to the router (the antennae, btw, should all be straight up). When you find the optimum orientation between the two, then test each available Control Channel making sure to wait about 5 minutes between channel changes.
When that optimum control channel is found, then test with turning/toggling the Universal Beamforming, MU-MIMO and other options available. Be sure you are giving the router time to re-adjust and become idle after all changes and before testing the three or four speed-sites you choose.
During all of this testing, do not move your laptop at all. Have it plugged in and at maximum power.
Close the browser window between each test. Keep excellent notes!
Messing around with fast.com, the further I go, the faster I get. Was getting 660 around 10' and 570 at 7'. All line of sight.
something wrong or I dont understand the world (could easily be but in this case I feel quite sure) ...Control Channel (Auto) - Auto always seems to pick busier channels, although it isn't something exclusive to this router it seems. I replaced a cat 5 cable connection to my PC with a Asus PCE-AC88 due some changes in locations but while the performance out of the box was good the connection speed wasn't near what it claims or the tests I had seen managing a connection speed of around 325 Mbps. Checking the control channels it had picked 36 which was somewhat busy near me according to wifi analyser, I decided to try channel 48 which was clear of other people and this seemed to boost all the 5Ghz devices connection speeds including my PCE-AC88 which now connects at around 1.4 Gbps.
To get 1.4Gb/s you need to set 80MHz bandwith (or even more 160).
And so it is meaningless which control-channel you will use al all channels 36-48 (or 64) will be used to get this 1.4Gb/s speed.
So not really a difference to set it to 36, 40, 44 or 48, different to 2.4G it will not use half bandwith around set channel up and down but in 5G it will allways use 36-48 for all of them.
Welcome To SNBForums
