I am wondering if anyone could help me to find out why I receive these faults in my router's log. It heppen every seconds during the night. My firmware is
3.0.0.4.384_5951
I even can't read any other massege beacuse full of my log with these
Thx.
Apr 26 03:00:00 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:01 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:02 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:03 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:04 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:05 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:06 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:07 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:08 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:08 acsd: acs_do_ci_update(398): ci scan failed ret code: -22
Apr 26 03:00:09 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:10 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:11 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:12 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:13 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:14 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:15 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:16 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:17 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:18 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:18 acsd: acs_do_ci_update(398): ci scan failed ret code: -22
Apr 26 03:00:19 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:20 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:21 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:22 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:23 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:24 acsd: acs_scan_timer_or_dfsr_check(1098): cs scan failed ret code: -22
Apr 26 03:00:33 acsd: staying in current channel as txop is recovered with in time limit
Apr 26 03:28:24 WATCHDOG: [FAUPGRADE][auto_firmware_check
6084)]period_retry = 0
Apr 26 03:28:25 WATCHDOG: [FAUPGRADE][auto_firmware_check
6110)]retrieve firmware information
6124)]no need to upgrade firmware
Apr 26 03:28:54 WATCHDOG: [FAUPGRADE][auto_firmware_check
6084)]period_retry = 1
Apr 26 03:28:55 WATCHDOG: [FAUPGRADE][auto_firmware_check
Apr 26 03:29:24 WATCHDOG: [FAUPGRADE][auto_firmware_check
6084)]period_retry = 2
Apr 26 03:29:26 WATCHDOG: [FAUPGRADE][auto_firmware_check
Apr 26 13:56:24 kernel: FPM Pool 1: invalid token 0x20278000 freed
