Is it working ??
Yes, and for me starts downloading as soon as you connect. Thanks!
Is it working ??
IPv6 was fixed with 102 firmware but is once again broken with 112 and 114.
just a reminder that everything works and is smooth as silk with tomato firmware...
http://www.4shared.com/get/5p0buBLH/tomato-K26USB-12804971MIPSR2-T.html
Thanks!
Why is toastman's builds hosted on such a (pardon my french) shirtty scamware site!?![]()
I'm gonna be the skeptic and ask for a source for this firmware. How do you guys know this firmware originated from ASUS? They've only released the source for .112 and haven't even officially compiled that and released it as a true firmware update. I would strongly caution anybody from using this .114 or anything that's higher than .108 at this point.
installed .114, thanks for the file.
Seems like HDCP reserve clients not working 100% for me, it cleared the clients i had, and now not it's populated on drop down menu, i may factory reset and flash again. Haven't seen anything different . Oh yeah, still can't detect clients on main screen either (maybe related bug to above)
Any new things/bugs with 114?
Anyone had issues with Port forwarding not working on this router? I apply it and it doesn't stick my settings! I would like to get my FTP up again. :/ I have version 108 firmware.
Not yet, but about too. :/
I don't think you need to enter the local port if it isn't different.Okay, I reset it and it still is not working. I manually entered the ports.
Enabled Port Forwarding
Famous Server List and tried manually entering it
Used 22 port range
Local IP to the local IP of that machine
Local port 22
Both for Protocol.
And it never shows up after I apply. :/ Log shows nothing.
Welcome To SNBForums
