theonlybabyface
I've installed 3.0.0.3.116b and it seems good so far. Will do more testing tonight.
Thanks! Now im woundering whats the differens between the .116 and the .116b. Any ideas ?
No idea, sorry![]()
.116 is for 56U and .116b is for 66U.![]()
No offense to anyone but anything coming from a .ru domain bothers me...I'm sticking to 114 until I see newer from non .ru domains.
I've installed 3.0.0.3.116b and it seems good so far. Will do more testing tonight.![]()
The motherboard ones were located in Taiwan when I spoke to them before...eh. asus engineers are based in russia.
k000;40444 How do I access the usb hdd (powered wd mybook) from PCs ? I plan on using synctoy Any suggesstions / better options will be greatly appreciated.[/QUOTE said:You can try to access it directly via router's ip (i.e. \\your router ip address). Name resolution has always been faulty in ms networks, and the reasons are often unclear.
I am new joiner here, found this great resource by googling.
I am running the .108 fw on n66u and want to be able to mount the usb hdd on couple of PCs to be able to keep the files in sync with each other as well as backup on hdd.
i have enabled the samba with additioanl account via asus gui, but can't seem to be able to find the share via Windows 7 (home premium) pc and laptop...
Just go in windows explorer under network and you will see your drive listed on the right side (RT-N66U)....
Welcome To SNBForums
