Jan 19 12:07:58 syslog: wlceventd_proc_event(526): eth3: Auth F2:A7:0F:88:4D:46, status: Successful (0), rssi:0
Jan 19 12:07:58 syslog: wlceventd_proc_event(536): eth3: ReAssoc F2:A7:0F:88:4D:46, status: Successful (0), rssi:0
Jan 19 12:08:44 syslog: wlceventd_proc_event(526): eth2: Auth F2:A7:0F:88:4D:46, status: Successful (0), rssi:0
Jan 19 12:08:44 syslog: wlceventd_proc_event(536): eth2: ReAssoc F2:A7:0F:88:4D:46, status: Successful (0), rssi:0
Jan 19 12:08:44 syslog: wlceventd_proc_event(507): eth3: Disassoc F2:A7:0F:88:4D:46, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 19 12:09:01 syslog: wlceventd_proc_event(526): eth3: Auth F2:A7:0F:88:4D:46, status: Successful (0), rssi:0
Jan 19 12:09:01 syslog: wlceventd_proc_event(536): eth3: ReAssoc F2:A7:0F:88:4D:46, status: Successful (0), rssi:0
Jan 19 12:10:09 syslog: wlceventd_proc_event(490): eth2: Deauth_ind F2:A7:0F:88:4D:46, status: 0, reason: Disassociated due to inactivity (4), rssi:0
Jan 19 12:10:09 syslog: wlceventd_proc_event(507): eth2: Disassoc F2:A7:0F:88:4D:46, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 19 12:10:19 syslog: wlceventd_proc_event(526): eth3: Auth 98:60:CA:A7:76:4F, status: Successful (0), rssi:0
Jan 19 12:10:19 syslog: wlceventd_proc_event(536): eth3: ReAssoc 98:60:CA:A7:76:4F, status: Successful (0), rssi:0
Jan 19 12:11:29 syslog: wlceventd_proc_event(507): eth3: Disassoc 98:60:CA:A7:76:4F, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 19 12:11:29 roamast: [EXAP]Deauth old sta in 2 0: 98:60:CA:A7:76:4F
Jan 19 12:11:29 roamast: eth3: disconnect weak signal strength station [98:60:ca:a7:76:4f]
Jan 19 12:11:29 roamast: eth3: remove client [98:60:ca:a7:76:4f] from monitor list
Jan 19 12:12:15 syslog: wlceventd_proc_event(526): eth3: Auth 98:60:CA:A7:76:4F, status: Successful (0), rssi:0
Jan 19 12:12:15 syslog: wlceventd_proc_event(536): eth3: ReAssoc 98:60:CA:A7:76:4F, status: Successful (0), rssi:0
Jan 19 12:12:48 syslog: wlceventd_proc_event(507): eth3: Disassoc 98:60:CA:A7:76:4F, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 19 12:12:48 roamast: [EXAP]Deauth old sta in 2 0: 98:60:CA:A7:76:4F
Jan 19 12:12:48 roamast: eth3: disconnect weak signal strength station [98:60:ca:a7:76:4f]
Jan 19 12:12:48 roamast: eth3: remove client [98:60:ca:a7:76:4f] from monitor list
Jan 19 12:13:00 syslog: wlceventd_proc_event(526): eth3: Auth 98:60:CA:A7:76:4F, status: Successful (0), rssi:0
Jan 19 12:13:00 syslog: wlceventd_proc_event(536): eth3: ReAssoc 98:60:CA:A7:76:4F, status: Successful (0), rssi:0
Jan 19 12:13:35 syslog: wlceventd_proc_event(507): eth3: Disassoc 98:60:CA:A7:76:4F, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 19 12:16:21 syslog: wlceventd_proc_event(507): eth3: Disassoc F2:A7:0F:88:4D:46, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 19 12:16:36 syslog: wlceventd_proc_event(526): eth3: Auth F2:A7:0F:88:4D:46, status: Successful (0), rssi:0
Jan 19 12:16:36 syslog: wlceventd_proc_event(536): eth3: ReAssoc F2:A7:0F:88:4D:46, status: Successful (0), rssi:0
Jan 19 12:17:50 syslog: wlceventd_proc_event(526): eth1: Auth 62:56:38:C7:36:31, status: Successful (0), rssi:0
Jan 19 12:17:50 syslog: wlceventd_proc_event(490): eth1: Deauth_ind 62:56:38:C7:36:31, status: 0, reason: Unspecified reason (1), rssi:0
Jan 19 12:17:55 syslog: wlceventd_proc_event(526): eth1: Auth 62:56:38:C7:36:31, status: Successful (0), rssi:0
Jan 19 12:17:55 syslog: wlceventd_proc_event(536): eth1: ReAssoc 62:56:38:C7:36:31, status: Successful (0), rssi:0
Jan 19 12:22:16 syslog: wlceventd_proc_event(507): eth3: Disassoc DC:52:85
C:53:9C, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
Jan 19 12:22:17 roamast: [EXAP]Deauth old sta in 2 0: DC:52:85
C:53:9C
Jan 19 12:22:17 roamast: eth3: disconnect weak signal strength station [dc:52:85:dc:53:9c]
Jan 19 12:22:17 roamast: eth3: remove client [dc:52:85:dc:53:9c] from monitor list
Jan 19 12:22:26 acsd: selected channel spec: 0xe32a (48/80)
Jan 19 12:22:26 acsd: Adjusted channel spec: 0xe32a (48/80)
Jan 19 12:22:26 acsd: acs_set_chspec: 0xe32a (48/80) for reason APCS_CSTIMER
