I can not get my AX11000 to flash to official now from the beta. I get invalid firmware error. tried re-downloading it, did a full reset on the router. Not sure what to do.
Echo - got the same.
Use Wifi to update. Update procedure is borked if done via LAN.I can not get my AX11000 to flash to official now from the beta. I get invalid firmware error. tried re-downloading it, did a full reset on the router. Not sure what to do.
Tried that - no good cannot go back to Beta RC1 eitherUse Wifi to update. Update procedure is borked if done via LAN.
On 386 rc2-10, GT-AC5300, after updating the firmware the web UI was unresponsive. After logging in, the UI hangs on GameDashboard.asp. Not sure if anyone reported this issue, but that's what I've noticed so far.
I have the strongest uptime since I bought GT-AC5300! 22 days and several hours with 10 beta release. Even if this will jinx it, it was a great run!
Can't really help you, I've never seen that. A power off and on few minutes later? A different browser?
Worst case scenario: a factory reset.
Solved - moved admin page local access authentication to https uploads fine now
What about this:
*****Update 2020/12/31 (9.0.0.4.386.41535)
386 rc2-10 - Google Drive
drive.google.com![]()
This version includes
ZenWiFi XT8, XD4, CT8
GT series: GT-AX11000, GT-AC5300, GT-AC2900
RT series: RT-AX88U, RT-AX92U, RT-AX86U, RT-AX82U, RT-AX58U, TUF-AX3000, RT-AX56U, RT-AX55
RT series: RT-AC5300, RT-AC88U, RT-AC3100, RT-AC86U, RT-AC68U
Due to compile problem, not in this version
ZenWiFi CD6, Lyra, Lyra mini, Lyra trio
Change log
- Fixed Let's encrypt register issue.
- Fixed packet loop problem in ethernet backhaul.
- To improve security, RT-AC68U starts to encrypt the NVRAM from this version.
Known issue: RT-AC68U needs to be reset to default to resolve the login problem after upgrading to this beta version.
If you want to downgrade to the previous version, you need to do it with rescue mode. <<<<-----
We are looking for a solution to this problem if you worry about this known issue, please wait for a further version and not update to this version.
Happy new year! *****
Doesn't that downgrade instruction apply to my AX11000? Right now im triying to update to the latest firmware version, not BETA, the new one, but i can't do it connected to the router network, i get an error, so im triying to do it from outside the network using my cellular data, but i have poor signal so its really slow to upload the file, so i just see the message " Please wait, Applying Settings... " ... Then my question is, if i downgrade to previous BETA version, i will be able to update from the same network? And i can just flash the previous BETA version or do i need to use the RESCUE MODE for it?
EDIT 1: Im triying to update using the external access link from the same wifi, i don't get an error, but all i see is the message "Please wait, Appliying Settings... "... It doesn't seem to move forward from that... Already 5 minutes there.
SOLVED: I updated my node first, without problems, then i retried to update the main router and it did it! All from local access (https).
I believe that note applies to the AC68U, not your AX11000.
I only manage firmware from a wired PC, using the router webUI, all on a UPS. I would not use a cellular link... too unreliable for flashing firmware.
I only use the default http for router webUI access.
OE
Yes @ASUSWRT_2020 please do not forget about us with RT-AC5300's :>@ASUSWRT_2020 is there a reason why in the latest update the tri-band models GT-AC5300 and RT-AC5300 are not mentioned at all, not even under testing?
Another note for the RC2-10 release for the GT-AC5300...the Traffic analyzer statistics seem to be off at least by a factor of 10 (or more). I initialized all of the traffic stats/AiProtection logs after the factory reset just to ensure things were starting off on a clean slate. Traffic stats are being collected normally, but the math is definitely wrong.
Yes, it's a mess! Both on web gui and on Android application.
I can't say I care enough about so I didn't send feedback about it.
If you care, use Feedback function from webgui.
Welcome To SNBForums
