Why do "security experts" feel the need to test against old, obsolete versions rather than the latest version?
Because there is a lot of old, obsolete versions in use out there.
Have been using merlins dualwan firmwares on asus rt-n16 since 2 weeks. The router has been rock stable and dual wan works perfectly. Thanks merlin for the firmware.
some details about my RT-N16 dual wan config
wan1 is a pppoe connection
wan2 lan port4 with automatic ip
dual wan is set to load balance mode and routing tables are enabled for dual wan. i have separately configured which connection each device should use in the dual wan page.
i have a very trivial issue.
Services(ping,ntp,ddns etc) on RT-N16(ip being 192.168.3.1) are unable to reach the internet with dual wan enabled.
so i tried adding router ip 192.168.3.1 to dual wan routing table. it works somewhat.
i am able to allow internet connection for router services by routing 192.168.3.1 to my secondary wan. but routing connection to primary wan - pppoe connection wont enable internet for router services.
as i told earlier its only a trivial matter and its solved for me , but just wanted to bring this to the notice of the developer.
just to highlight how great a dualwan router the rt-n16 is - Had been earlier using dualwan tomato firmware from dualwan.cn on my rt-n16 since about 2 years. Dual wan had been rock stable and reliable on this tomato firmware too , but updates to the firmware has stopped.
Thanks merlin again for the dualwan firmware.
RMerlin what do the letters near the Control channel mean. For example when I am changing a control channel on the WLAN it has a letter after the channel ?
Also thank you for this release. I have been waiting for this final release for a while and have moved from 270_26b to this one.
Does it mean that, for example, I can not use the TCP port 443 for OpenVPN server now? In GUI I've marked that web access is not permitted from WAN side and nobody listens on TCP 443 from WAN side -I've checked it!
I just upgraded from .270.25 to 372.31 and now I have poor wan throughput. I have a 250/250Mbit connection and with my computer connected directly to wan I get around 240/220Mbit stable throughput. When going through my RT-N66U my throughput varies between 180-50/90-50Mbit.
Anyone have any idea how I can troubleshoot?
(before and after upgrading I cleared nvram)
Welcome To SNBForums
