hi hoping someone may of had this or it is something silly i am doing.
Ok never really had any problems with any of the FW apart from the 5ghz wi fi.
But i have just upgraded from .26b to .32 did a clear reset of the nram and all is ok apart from my usb stick that i had mounted in one of the usb openings.
When i log on it shows my HDD mounted ok but the 32GB memory stick unmounted and no matter what i do it will not mount.
I have tried removing it then plugging back in and that makes the whole router crash and reset it self(says something about port number/ip address change)?????? also have tried reformatting it the same as before, as NTFS, but it still crashes the whole router??. But for some reason the HDD that is in the other usb slot has always worked and is still working though all the upgrades.
Thanks for any help here
Pete
