Release Asuswrt-Merlin 3006.102.3 is now available for WIfi 7 devices
RMerlin
Asuswrt-Merlin dev
Staff member
Asuswrt-Merlin 3006.102.3 is now available for supported Wifi 7 models. This release focuses on updating to a new GPL, and fixing issues.
Please make sure you read the changelog for important information if flashing Asuswrt-Merlin for the first time on top of the original Asus firmware.
3006.102.3 (11-Jan-2025)
  - NOTE: If flashing on top of Asus stock firmware 3006.102_37000
          or greater, then you first need to enable downgrade
          capabilities before flashing Asuswrt-Merlin on top
          of it.  Connect Over SSH, and run the following command:
             nvram set DOWNGRADE_CHECK_PASS=1
          After that, you can upload Asuswrt-Merlin through
          the webui like any regular firmware upgrade.
          This is only required when flashing Asuswrt-Merlin
          for the first time.
  - NOTE: The new GPL codebase changed the way wireless networks
          are configured.  If you ever revert to an older
          firmware, you MUST do a factory default reset following
          the firmware downgrade, on both the router and any
          existing AiMesh nodes.
  - NEW: (re-added) VPN interface selector on the Speedtest page,
         to test a VPN tunnel's throughput.
  - UPDATED: Merged with GPL 3006.102_37346 (with the wifi firmware
             from 37038 for the RT-BE96U and GT-BE98_PRO - was missing
             from GPL)
  - UPDATED: dropbear to 2024.86.
  - CHANGED: VPN public IP retrieval now uses HTTP instead of STUN,
             which should be more reliable through a VPN tunnel.
  - CHANGED: Model name will be inserted in the filename of JFFS backups.
  - CHANGED: Display DHCP leases from other VLANs
  - CHANGED: Improved refresh behaviour of the VPN Status page.
  - CHANGED: Set rp_filter mode to "loose" on Wireguard client interfaces.
             Fixes gettunnelip.sh and onboard speedtest.
  - FIXED: webui always redirecting to router hostname for RT-BE86U.
  - FIXED: DLNA device icon missing for GT-BE98_PRO
  - FIXED: Site Survey page not loading properly
  - FIXED: Wireless Log would sometimes display the wrong hostnames
  - FIXED: Refresh link not working on OpenVPN/Wireguard client pages.
  - FIXED: WireGuard client randomly failing to retrieve public IP for
           display on the webui.
  - FIXED: Some Guest Networks wouldn't properly list their
           connected clients on the Wireless Log page.
Please keep discussions in this thread on this specific release. This thread may be locked after a few weeks..
Downloads are here.
Changelog is here.
Reserved post.
As mentionned in the changelog, Asus reworked the way wireless networks are configured internally with recent 3006 releases. The main wireless settings are now configured as a subunit (subunit 1) rather than at the root of the unit. So if you have any custom script or Add-On that interfaced with Wireless settings, don't expect these to still work properly. They will need to be updated to the new internal storage.
