Fester1952
I already write RMerlin about this problem and make issue
https://github.com/RMerl/asuswrt-merlin/issues/723
And find solution
Thanks Andrey
And find solution
And find solution
On LAN-> IPTV Page i can't set to "Enable" two options,
Enable multicast routing (IGMP Proxy)
Enable efficient multicast forwarding (IGMP Snooping)
When i try set options to "Enable" and press "Apply" button to Save changes, page refresh with "Disable" options.
My HW: RT-N66W
I can verify that the VPN settings are no longer working properly, just as you described. RT-AC66U. Thanks.
Just a quick and dirty report for both RT-N66U and RT-AC68U which were both previously on the 374.43 v3 Fork by john9527.
On wireless, both bands seem to be back up to close to 374.43 firmware speeds. Close enough that I am staying on the this Beta 1 for now.
As for usage mode, these routers are used for basic internet, wifi and lan (RT-N66U) and the RT-AC68U is used in Dual WAN load balanced mode with again, basic internet, wifi and lan access. Each network (in different parts of the city) have about a dozen wired clients and about twice that for wireless across both bands.
Thanks again RMerlin for such a great release, even when it's just designated as a Beta.
Running since Monday, works great! I do see a few more errors with my HD in the log but that has been the case since the change in the USB drivers. Reducing USB 3.0 interference is disabled
Sep 17 13:45:29 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
Installed Beta 1.
My RT-AC68U now runs very hot. The CPU temperature is 90 degrees C which is unacceptable if the CPU is idling.
See here:
Is the firmware reducing the life of our router?
Question... Is anything changing here, in terms of drivers / updates for the core system on the AC68U? Or mostly just features? I know it's a merge with the most recent Asus code, but do they typically make tweaks with every release?
The firmware has nothing to do with the temperature.
I currently have the RT-AC87R with the 376.47_beta1. What is a normal or "good" temperature for the CPU to run at? Mine is currently at 82 degree's Celsius. Not quite 90 like the other guy but still pretty hot.
This problem happens with Asus firmware and Merlin's. (USB problems)
Hi RMerl, I haved installed the beta on my RT-N16 and went over all the configuration pages looking for SNMP... but with no luck.
Welcome To SNBForums
