Hello,
First of all, thank you Merlin for putting out so much effort in developing the firmware! I glanced through the threads and changelogs for latest 376.48 beta2, stable 376.47 and fork 374.43 and decided to give a shot for the latest beta for n66u which was running latest stock FW. I'm not sure whether it was a user error or something else but I managed to lose the settings to default after reboot, multiple times with different FWs. Simply put, what I did was:
1) Unplug all but desktop LAN, switch off all wifi devices, flash beta, power off with button, cord off 30seconds, cord back, WPS pressed 10 seconds during switch on and then relased. I configured the router settings by applying all the changes on every page. Then I decided to give it one reboot via webui to leave it running "fresh". Kaboom, all settings lost and I was greeted by the setup wizard. I configured the settings twice, rebooted afterwards via webui and lost the settings again.
2) Then I did the same procedure (with the factory reset to be sure) with the latest stable. Same thing, settings lost.
3) Then I lost my faith and flashed back to stock BUT decided to save the settings (learned my lesson finally) and do the final reboot with power off button, for some reason which I don't remember. After reboot everything was there. Okay, I noticed that probably it was necessary either to save the settings to disk (don't understand why this would have anything to do with the case) or reboot with power button instead of webui reboot. I never loaded the saved settings, just saved to disk.
4) I regained my faith and flashed with beta again, did factory reset, changed settings, saved, rebooted with power button and all settings were there. I even engouraged to do webui reboot afterwards and no problems whatsoever.
Do you guys have any explanation why power button reboot together with saving the file to disk would have anything to do with NOT reverting the settings to default? Did I do something wrong? I did the factory reset every time immediately after flashing the FW, before doing any configuration changes, i.e. I did not clear the NVRAM after doing the changes.
I just realised that maybe logs would have been crucial but I was fiddling in the middle of the night and neither thought of saving the logs or writing to the forums. Same kind of issues are described here:
http://www.dd-wrt.com/phpBB2/viewtopic.php?t=80954&postdays=0&postorder=asc&start=0&sid=3008387d0ef340c30fe1a091fb94b506
Another question, what could be the reason for terrible ping both with 2.4GHz and 5GHz wlans? I had the same problem with the stock rom and with all of listed FWs which I tried? Although the connection is established, it can take up to 10 seconds before I get ping responds or web pages loaded. But then, after the initial lagging, everything is somewhat smooth until I leave it be for a while. This happens only with laptop (samsung series 9, 900x4d with Linux Mint 17 x64). Some hardware issue with my laptop? I did not have this problem with netgear. Do you recommend trying to change some specific setting? Could NAT acceleration have anything to do with this? Any improvements vs. flaws expected concerning the wifi issue, if I downgrade to fork 374.43? Thanks, and sorry for rumbling to the forums with highly potential TL;DR post.
