Asuswrt-Merlin 378.56 Beta 1 is out
Mediafire still working on my issue, and so far it seems they don't really know what is happening.
Therefore I have setup a project page on Sourceforge, and uploaded both 378.55 and this 378.56 beta release there:
https://sourceforge.net/projects/asuswrt-merlin/files/
Will be testing them as a potential alternative to Mediafire if they can't sort out the various issues I've been having with their service.
People who are in doubt, remember that you can always use the sha256 hash to validate whether a downloaded firmware is legitimate. Hashes are posted on a totally separate location from the downloads (my website), in addition to being included in every archives.
What happened to the AC66U beta fw size? 378.55 is 30MB while 378.56 Beta 1 is 21MB.
Is there no other alternative than SourceForge? I really hate those malware spreading bastards. Many projects moved away from them a long time ago for good reasons.
On AC66ubeta1 I think I'm missing dual wan setting (when to switch/failback/etc). It is missing on main page too. Only one WAN is showing
Did you check the internet status page? Click on the Globe, internet status, enable/disable dual wan.
I've found a bug in the GUI, when you are on the adaptive QOS bandwidth monitor page and hover over the system log icon it activates the apply button on the bandwidth monitor page.
Dual wan enabled on internet status brings this up.
Hope I didn't miss this but does the battery drain affect Apple devices? There's mention this update is better for Apple devices but it also mentions some devices will experience faster battery drain.
Just unclear if battery drain also applies to iOS devices and Apple laptops.
Curious if the realtime traffic monitor is working correctly with the RT-AC68U/P yet? I'm hoping for a fix to that from Asus.
Thanks.
"RT-AC66U:
Updated to .56 beta and a few hours later noticed that my 1T Toshiba USB drive was not mounted."
OK - at risk of appearing to know what I'm looking for-
I clear the log and reboot on *.55. The USB drive entries are:
Oct 13 15:54:45 kernel: sda: sda1
Oct 13 15:54:45 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Oct 13 15:54:45 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Oct 13 15:54:46 hotplug[497]: USB /dev/sda1(ntfs) failed to mount at the first try!
Oct 13 15:54:46 usb: USB /dev/sda1(ntfs) failed to mount At the first try!
Oct 13 15:54:46 kernel: ufsd: use builtin utf8 instead of kernel utf8
Oct 13 15:54:47 kernel: ufsd: sda1 without journal
Oct 13 15:54:47 syslog: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/Hope
Oct 13 15:54:47 usb: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/Hope.
So then I clear the log, upgrade to *.56beta and reboot:
Oct 13 17:01:36 kernel: scsi 0:0:0:0: Direct-Access SAMSUNG HM100UX PQ: 0 ANSI: 2 CCS
Oct 13 17:01:37 rc_service: ntp 459:notify_rc restart_diskmon
Oct 13 17:01:37 disk_monitor: Finish
Oct 13 17:01:37 disk monitor: be idle
Oct 13 17:01:39 kernel: sd 0:0:0:0: [sda] 1953525168 512-byte hardware sectors (1000205 MB)
Oct 13 17:01:39 kernel: sd 0:0:0:0: [sda] Write Protect is off
Oct 13 17:01:39 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Oct 13 17:01:39 kernel: sda: sda1
Oct 13 17:01:39 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Oct 13 17:01:39 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Oct 13 17:01:39 hotplug[484]: USB /dev/sda1(ntfs) failed to mount at the first try!
Oct 13 17:01:39 usb: USB /dev/sda1(ntfs) failed to mount At the first try!
Oct 13 17:01:39 syslog: USB /dev/sda1(ntfs) failed to mount at the first try!
Obviously that's just the extract of what looked related, but I can upload the whole thing if need be.
Its completely reproducible that changing between the two firmwares mounts/unmounts the drive.
Thanks.
Reproduce the issue with the stock firmware, then provide a detailled report to Asus in the official Asuswrt forum. I must admit I'm unable to understand the problem you are trying to describe, and I know there are quite a few users who are succesfully using Dual WAN.
Aug 1 08:01:13 rc_service: wanduck 422:notify_rc restart_wan_if 0
Aug 1 08:01:13 dnsmasq[444]: read /etc/hosts - 5 addresses
Aug 1 08:01:13 pppd[514]: Unable to complete PPPoE Discovery
Aug 1 08:01:13 pppd[514]: Hangup (SIGHUP)
Aug 1 08:01:13 pppd[514]: Terminating on signal 15
Aug 1 08:01:13 pppd[514]: Exit.
Aug 1 08:01:13 kernel: Attempt to kill tasklet from interrupt
Aug 1 08:01:13 kernel: br0: port 1(vlan1) entering forwarding state
Aug 1 08:01:13 kernel: device eth0 left promiscuous mode
Aug 1 08:01:13 kernel: device eth0 entered promiscuous mode
Aug 1 08:01:13 kernel: br0: topology change detected, propagating
Aug 1 08:01:15 wan: mac clone: [wan0_hwaddr] == [00:24:**.**.**.**]
Aug 1 08:01:15 pppd[689]: Plugin rp-pppoe.so loaded.
Aug 1 08:01:15 pppd[689]: RP-PPPoE plugin version 3.11 compiled against pppd 2.4.7
Aug 1 08:01:15 pppd[691]: pppd 2.4.7 started by shaobing, uid 0
Aug 1 08:01:16 rc_service: wanduck 422:notify_rc restart_wan_if 1
Aug 1 08:01:18 wan: [wan1_hwaddr] == [AC:9E:17:93:C0:C7]
Aug 1 08:01:35 rc_service: zcip 697:notify_rc start_firewall
Aug 1 08:01:35 dnsmasq[444]: read /etc/hosts - 5 addresses
Aug 1 08:01:35 zcip client: configured 169.254.44.74
Aug 1 08:01:35 start_nat_rules: apply the nat_rules(/tmp/nat_rules___)!
Aug 1 08:01:50 pppd[691]: Timeout waiting for PADO packets
Aug 1 08:03:05 pppd[691]: Timeout waiting for PADO packets
Aug 1 08:04:20 pppd[691]: Timeout waiting for PADO packets
Aug 1 08:05:35 pppd[691]: Timeout waiting for PADO packets
Aug 1 08:06:51 pppd[691]: Timeout waiting for PADO packets
Aug 1 08:07:50 rc_service: httpd 450:notify_rc restart_wan_if 1
Aug 1 08:07:52 wan: [wan1_hwaddr] == [AC:9E:17:93:C0:C7]
Aug 1 08:08:06 pppd[691]: Timeout waiting for PADO packets
Aug 1 08:09:21 pppd[691]: Timeout waiting for PADO packets
Aug 1 08:10:36 pppd[691]: Timeout waiting for PADO packets
Fiber Modem is connected, you can connect to the network using 1WAN, everything is normal / when using 2WAN, WAN can not get to a public IP, lan (when WAN2 used) can not get into the fiber port Modem intranet IP. That is the time when using 2WANYou can not detect PPPOE link.
Thanks I hope my printer stops waking me up with it's lights all night now.
Thank you for fixing mobile login. Not being able to log in and the light in my eyes was driving me psychotic!
If they are going to provide me with free download hosting, and they have no way of inserting any malware or adware in my downloads (because they aren't Windows installer), then I don't care who they are or what they've done.
The other alternatives are worse on a technical level. I need somewhere to host files that generate around 300-500 GB of monthly traffic. You don't put that on any 10$ VPS with a 100 Mbps uplink... Downloads would be slow as a crawl during release peaks, and be slow for the users accross the globe. SF has a CDN to offset problems.
Ideally, I'd love to see Mediafire resolves the current issues (and those long-standing issues where their web interface is buggy as hell). But I'm just starting to lose any hope there, so I'm looking at a plan B.
Keep me informed if the fix does work, as I have no way of testing it. 40$ USB printer plugged to my PC here, I print maybe once every 3 months on average...
That would be Asus. They've done a lot of changes to the login page over the past month or two.
That's a long-standing bug that I fixed a few months ago. It might have crept back in a recent merge (I also noticed it last night).
Not sure, I haven't really kept track of details on that issue. I don't have any Apple device, so the only device I had that reproduced the issue was my Nexus 9.
Thanks.
Looks like it's trying repeatedly to mount it, but failing, with no report as to what is failing.
I can't reproduce the issue here with my own HDD, and I'm not familiar with the details of the USB implementation (the code is quite complex, and undocumented). See if you can reproduce the problem with the stock Asus firmware, and if yes, report it on the ASUSWRT - Official Firmware forum here so they can look into it.
