I have philips hue, i had to reset my ac68u 3 times to make it workDid a fresh install with factory reset on all 3 of my routers. I have my main AX88U running in AP mode with the other 2 as AIMesh nodes hardwired. My devices keep dropping from the network, and I have noticed my Lifx Bulbs dont work with this update.
I have philips hue, I had to reset my ac68u 3 times to make it work![]()
They doDon't Hue use Zigbee though? Mine do...
They dobut the bridge needs internet to philips cloud, and the bridge would not connect to the cloud until I had reset 3 times
I have philips hue, i had to reset my ac68u 3 times to make it work![]()
More ON topic though, I have just been struggling with connectivity between machines that are connected to the node.
Plex and other things cannot be accessed from machines that have chosen to connect to the AIMesh node. AIMesh Router <--> AIMesh Node is not working for me. Everything is on the internet, but routing isn't happening between them.
I think you are right with most of the problem being Aimesh. I have found if I shut my nodes down, most things go back to normal. But... I need the nodes for devices that are out of normal range.
Yup, I had tinkered with it before posting, but I tried rebooting router and node both, then using the new Optimization option in AIMesh, and now things seem to be talking. Time will tell if it lasts.
It's a beta, and if anything is wrong, it is sorta on us for being anxious to try it before releaseBut AIMesh carrying Guest is huge, and such a shiny new option can only sit on a shelf so long before we succumb to the call...
I have gone straight from 384.19 to 386.1 Beta 1 without factory reset, but I'm not sure I would call that "dirty"...Are there folks who have (successfully) gone from 384 > 386 “dirty” without factory default reset?
(Those who didn’t use alpha)
Folks, @RMerlin recommends that you do a factory default reset under various scenarios:Are there folks who have (successfully) gone from 384 > 386 “dirty” without factory default reset?
I think my brand new RT-AX86U may be bricked
I upgraded from Alpha4 and did a factory reset, configured basic networking and everything seemed fine. Then I enabled jffs and ssh and copied the openvpn and usericon directories from backup and proceeded configuring the router. I also committed my dhcp_staticlist to nvram
First sign that something was wrong was that the web interface stopped working. Wifi was ok and I could still log in via ssh but after reboot it's just stuck in a boot loop.
I can put it in rescue mode and I've tried restoring stock firmware as well as Merlin alpha4 and beta1 numerous times without any luck. The Asus tool says restoration was successful but it still won't boot.
I've run Merlin on all my older Asus routers for years but never gotten into trouble like this. I'm at a loss, please help?
@Wowbagg3r You can try a manual hard factory reset. Maybe you can recovered it from the loop. The process is described in the Asus Web.
And you never should use a backup between versions. I think Alpha had some issues with some nvram values.
Yes. I have updated three of my four Asus routers that way (one AX-88U and two AC-86U's). All came from 384.19 Release to the Beta 1 via Dirty Upgrade. The fourth one is my main router and will wait for the Release version before upgrading that.Are there folks who have (successfully) gone from 384 > 386 “dirty” without factory default reset?
Welcome To SNBForums
