Beta Asuswrt-Merlin 386.1 Beta (stage 2) is now available
If I recall, TransAmiga (the BBS software me and a friend used to run back in the day) went through beta, then gamma releases (1.10g1, 1.10g2, etc...).
Amiga! Your are showing your age now. Great graphics - miss the bouncing ball demo ;-)
I used to run a 4 line Wildcat BBS under IBM OS2 Warp3. :)
I ran pcboard under desqview, then os2 :) (my irc nick is LiveWire, after the os2 comm program).
I still have an old IBM compatible PC [Cordata-Company out of Compton,CA] 386SX16 [no math copressor] with OS2 Warp installed from 40--3.5" floppy disks (still have them) because I couldn't afford to add a CD player back then. I few years ago-out of nostalgia-turned it on to play with OS/2 but without a working serial mouse couldn't remember how to navigate around the GUI.
Will there be a dnsmasq 2.83 update by @themiron before beta 5? Both Pi-Hole and OpenWRT have pushed out updates today.
That's currently the plan, will depend on whether he has spare time to do it, or if I do it myself. In the mean time disabling DNSSEC should be good enough (and ensuring you use an upstream DNS server that you trust).
Double update by Pi-hole. FTL 5.5.1 shortly after. Heh.
I don't know if this is TrendMicro closed-source or not but I just stumpled upon a "bug" in the "monthly"-statistics. The "numbers" in "date" doesn't make any sense to me.
Weekly and Daily numbers (meaning dates and times) are correct - but monthly looks like this... (the description - not the values!)
really not important - just reporting...
RT-AX86U with Beta4
oh... ok, my bad - sorry - looked strange for me - but yes - explained it makes sense.
Hoping that Merin can roll out beta 5 within the coming weeks, but hey, its ready, when its ready right.
i deal with this all the time at work. It's usually US users that struggle. I keep advocating for yyyy-mm-dd in our communications to avoid confusion....
Yep an going problem/debate, as some people prefer DD-MM-YYYY, also to avoid confusion, as long as people are clear on the format, does it really matter, I don't think so. Its a medium I am sure many people have different opinions about. For me not an issue, its a simple look and see, its not rocket science to work it out.
When you say disabling dnssec, are referring you to the early stage dnssec Vulnerability?
