Beta Asuswrt-Merlin 386.1 Beta (stage 2) is now available
From 384.19 to 386.1b5 working fine on my basic config with 3 clients. Thanks!
Edit: Did a full reset too since I haven't for awhile.
Updated both AC86 units to beta5, so far so good. Will check again in morning. Thanks Merlin, you're a Wizard. ;)
So far Beta 5 working great on the AX58U's and 68U
Updated on my AX-86U, seems to have updated nicely.
I'll give running scripts with amtm on this version a go and see if it's stable now. I've had unstability on the previous version.
@ Eric, with beta 5 the issue with guest network is no longer there when using RT-AX88U and guest network 1, if you like i can run additional test, but so far everything is looking good.
Do you mean the issue with the log message?
Upgraded from 384.19 to 386.1b5 and getting stuck at around ~240Mbps download speed still, LAN as well as WIFI. I had the same issue on Beta 3 and Beta 4. Downgrading to 384.19, download speeds are fine (Gigabit, 700-900Mbps usually).
It's basically acting like QOS or NAT Acceleration are On respectively Off, but they're not (QOS is Off, NAT Acceleration on Auto)... exact same settings on 384.19 as on the 386.1 Betas. Not sure what else to try other than going back to 384.19 again. This is on a AC88U. :confused:
upgraded from b4 (1st version) direct to b5 via webUI (on 2nd try with USB unmounted).
only issue is that guest clients don't show on the network map under the guest network sections.
but it may be related to me using YazFi
I still had the issue here when I tested it, make sure you check with dmesg, not syslog. Also need to have a 5 GHz client transfering data at the same time.
I tested with 2.4, will check with 5 and see how it goes.
Jan 25th: Beta 5 is now available. Changes since Beta 4:
3790c8fe9a Updated documentation
fd1cb1eacd dnsmasq: update to 2.84 final
6ecc2e1df5 dnsmasq: update to 2.84test3 (openssl/2.84test3-40-gee342e7)
7328ccf7d8 dnsmasq: update to 2.84test3 (openssl/2.84test3-36-g5790ea0)
2585ca7b3d wsdd2: Also bind to specific interface when listening to SSDP address
fa6b3b0502 wsdd2: identify as ASUSWRT WSD rather than NETGEAR WSD
e0b64349d2 Merge 386_41700 binary blobs + SDK for RT-AX58U
96010951e0 Merge 386_41700 binary blobs and SDK for RT-AX56U
c43ea32f3d Merge 386_41700 binary blobs and SDK for RT-AX86U
4f37b74bfb Merge 386_41700 binary blobs + SDK for GT-AC2900
2900dc0d46 Merge 386_41700 binary blobs + SDK for RT-AX88U
a679101f9c asd: re-enable on all models
06182cb7e7 Merge 386_41700 binary blobs + SDK for RT-AC86U
5e9564e6bf Merge 386_41700 binary blobs for RT-AC88U/RT-AC3100/RT-AC5300
5512e8a4d4 build: add cleanup section to copy-prebuilt
eee7484d6f Merge GPL + binary blobs from 386_41700 (RT-AC68U)
10aff689a1 Bumped revision to beta 5
72b2a94f58 SDK 5.02p1: cleanup SDK
12bf0ba323 SDK 5.02p1: fix pwrmngtd module building
a5ea4eb7de axhnd: cleanup SDK from build leftovers
603b0b45bc rc: replace missing include with publicly obtained defines
83eeea819d libovpn: correct error message when trying to start already running server
82ab0809b6 rc: don't use prebuilt init-broadcom
6d4d79b48a SDK 4908: revert bdmf.o to 386_40577 version
This contains dnsmasq 2.84 (which was released only three hours ago by its author - just saying...) which resolves security issues, as well as IPv6 breakage that was introduced in 2.83.
RT-AC86U CPU idle fix from Asus's 386_41700 GPL is included (replacing my own temporary fix).
Appreciate this...downloading now and we'll monitor. Feels like Christmas again. Thanks RMerlin.
