maxbraketorque
I would install now, but daily backups are running.
Main problem is whether this will also improve the general experience under other scenarios (like multiple clients running at once, mixture of streamed + latency sensitive applications, etc...). And also whether you need to take into account VLAN tagging when handling traffic from the br0 interface, etc...FWIW, the Cake experiment worked well for me on beta2. I can get 338 down instead of low 200s.
I don't know if you saw @Vergo 's comment here: https://www.snbforums.com/goto/post?id=674269 , but the comment of interest was:I also implemented a potential fix for the rstats traffic spikes. I have no way of testing it, so I have no idea if it resolved that particular issue or not - feedback from users who are able to reproduce the problem would be appreciated.
So if your new approach doesn't work, perhaps something similar could? (It was a setting that I initially didn't use for vnStat-on-Merlin, because I wasn't clear on what it did, but it may help control those false spikes)."BandwidthDetection" is a way of querying the network interface driver for the maximum bandwidth that the interface is capable. If that driver provided information isn't valid then there isn't much vnStat can do. Complain to the manufacturer if you happen to have connections that way. If the driver however opts to provide no information at all then vnStat uses "MaxBandwidth" as fallback value to act as a sanity check for the seen traffic. If the traffic is higher than the given value then it gets ignored. This is used to eliminate "ghost traffic" and other kinds of traffic spikes that may occur due to device driver implementation issues and other reasons. I'd highly recommend not setting "MaxBandwidth" to zero.
I see Cake like a thermostat. You might adjust it frequently as the seasons change, but mostly set it and forget it once you find your comfortable settings.So, I'll be sticking to the most basic setup that is known to work for almost everyone, and leave any finetuning to the community. That is why I spent so much effort in providing flexible "hooks" to allow people to completely customize the way Cake is implemented. Maybe if a few months down the road someone comes with a widely tested architecture that could make sense I might switch implementations, but for the 386.2 release, this will be considered "good enough".
3b449faf84 rc: revert static DNS routes added with GPL 42095
For testing cake performance, here is a test that has been discussed on the Bufferbloat project's email list:
Bufferbloat and Internet Speed Test - Waveform
Is bufferbloat causing issues with your internet connection? Run this test to find out.www.waveform.com
I got an A without any additional tweaking of the 386.2 beta 2 default configuration.
RT-AX58U 150 Mb/s down 20 Mb/s up, cable/docsis. Because Comcast overprovisions bandwidth by ~ 15%, I went w/ 100% of my subscribed values.
Can confirm, it now limits download with beta2. But I don't see any difference using this.
Also, in my opinion besteffort should be the default for upload instead of diffserv3. But I understand why you would choose diffserv3, a lot of people work from home now and use zoom/teams.
This test works much better than the DSLReports test. I love that they provide the actual timings.
View the full results, and test your own bufferbloatwww.waveform.com
I'm on Verizon FIOS with an old 100-Mb symmetric limit. They offer much more. I've only had one outage in over 10 years and that was when there router failed. I use there router and thus have double NAT which is OK with me. This way they provide full support for my setup.Jez, that's amazing, i wish i had results like those. My ISP is trash, I have fiber 10 meters from my house, yet they don't install it.
Stuck on adsl2+. I think i need to try a new modem to see if it lowers my bufferbloat.
What's even worse is that adsl2+ clients are have to pay the same as FTTH clients with 200/100 or 500/100.
Welcome To SNBForums
