Asuswrt-Merlin 386.4 is now available for all supported models. This release merges with GPL 386_45958, and adds support for the RT-AX86S.
Dec 28th update: Updated to Beta 3. Changes since Beta 2:
Dec 22nd update:: Updated to Beta 2. Changes since Beta 1:
There has been a long gap between these last releases due to licensing issues Asus had to resolve with the generated GPL archives. There are still a few remaining issues that are currently forcing me to delay support for the RT-AC68U_V4 and GT-AXE11000, these will need to be revisited once their respective GPL archives are fixed by Asus and Broadcom.
The highlights of this release;
Please review the Changelog for complete details.
Notes:
Things that needs particular testing and feedback:
Please keep posts in this thread on this specific release.
Downloads are here.
Changelog is here.
9288cd8c05 Updated documentation
8c0194de99 inadyn: rc: disable IPv6 support
0ae53e9cd8 rc: harmonized with upstream
969b828b98 busybox: enable hexdump applet
cf0307f1d2 rc: add missing chain to ip6tables's filter table
797f3e4ba9 httpd: webui: improve parameter sanitization (backport from Asus upstream)
f672e3199a Bumped to beta 3
shared: improved buffer validation (backport from Asus upstream)
bcbd5e494b shared: Replace the source code of strlcpy() and strlcat() by BSD verison (patch from Asus upstream)
8247d74c37 rc: ensure that do_dns_detect() always has a valid test server even if nvram is empty
77917ed54c rc: also add static lease hostnames without domain appended to host file
0b69989b80 rc: start miniupnpd after getrealip has run, and give it an extra 5 secs in case it's not ready yet
abe3f8f883 httpd: also fix potential NULL ptr access in do_vpnupload_post() (patch from upstream)
c02ac3af36 Updated documentation
49b788dd06 Merge pull request #796 from decoderman/master
da11794861 build: fix et userspace tool copy on SDK 6.37
15ccb9cbfb amtm 3.2.1 release, preparation for IOS Shortcuts
03c9fdcf06 httpd: fix potential use of uninitialized variable in do_vpnupload_post(), introduced in 6ce76323bf
71732c5a66 rc: reapply firewall-start rules after stop_ddns() restores them from filter_rules
1c5a36e089 openvpn: updated to 2.5.5
6ce76323bf httpd: improved buffer validation (backport from Asus upstream)
8d40f2c18a ddns: backport patches from Asus upstream
c09e1fae34 inadyn: revert ddns.c fix
e2243b0df9 openssl: updated to 1.1.1m
d167e13d6b Bumped revision to beta 2
- Merges with GPL 386_45958.
- Adds support for the RT-AX86S (uses the same firmware as the RT-AX86U).
- HND firmwares now include both the kernel module and userspace tool for Wireguard. There is no built-in support for Wireguard at this time, these are only included for end-user or third party usage. Asus is still working on their own implementation, which isn't available yet.
- OpenVPN server now supports IPv6, both for incoming connections, and for routing access to the LAN clients over IPv6. Note however that redirecting IPv6 Internet traffic through your server is not supported.
- Component updates: curl 7.79.1, vsftpd to 3.0.5, openssl to 1.1.1m, wget to 1.21.1, nettle to 3.7.3, dnsmasq 2.86, openvpn 2.5.5, tor 0.4.5.11, miniupnpd 2.2.3-git 20211017 and inadyn 2.9.1
- jitterentropy-rngd was replaced by haveged. Haveged is more resource-intensive, but it works properly under older 2.6.x kernels.
- dnsmasq was reverted back to using nettle for its DNSSEC crypto handling (since openssl support never got mainlined and was increasingly problematic to support)
- miniupnpd now uses the real public IP address instead of any potentially (double-)NATed address for the WAN.
- Reworked DHCP hostname support to use Asus's own implementation.
- A couple of various bugfixes
Notes:
- 386.4 uses the new DHCP hostname implementation from Asus (your entries will automatically be converted to the new format on first boot). This means however that reverting to a previous firmware version will lose all of your defined static lease hostnames.
- OpenVPN server IPv6 support. I was only able to do limited testing using an HE tunnel.
Downloads are here.
Changelog is here.
