Release Asuswrt-Merlin 386.9 is now available for AC models
I've had this issues for a bit, any version after 386.5_2 forces on trend micro's AI protection even with it off, on firefox it causes a lot of SSL_ERROR_RX_RECORD_TOO_LONG errors when you got on sites trend micro has decided are malicious. What do I do to fix it? I'm using an RT-AC86U. I just tried updating to 386.9 and the same problem occurs.
Well, there is the laboursome but working step-by-step fallback: Do a WPS reset and set it up as a normal router, run upgrade, do a WPS reset and set ut up as an Aimesh node again.
That being said, I prefer running stock firmware on my Aimesh nodes - i reserve Merlin for the main router, as it offers no advantage on an Aimesh node. You also have the advantage of being able to do firmware by semi-automatically in the GUI (simply click "update" when there is a new update detected). Stock firmware is also newer.
Thanks took your advice and all is good now
I'm using ASUSwrt Merlin on my RT-AC66U_B2. Today I upgraded to the latest build 386.9. Everything is running smooth, exept getting the "Low on NVRAM" exclamation. Never seen it on previous versions :confused:
Actually about 2,8 k are free. I checked some advices here at SNB regarding this issue, but I was unable to resolve it. There are no large variables in NVRAM.
Some hints?
Looks like the log was killed when I reverted FW. I only have new log entries. I'll have to repeat the process and see...
What does the log say when the disconnection occurs?
I had problems with a wired AC66U-B1 Aimesh node routinely dropping both clients and an AC68U wireless Aimesh node that connected to it at short, reoccurring intervals at one point running 386.7_2.
Solution: WPS reset the AC66U-B1 and then set it up as an Aimesh node again. The problems stopped, and has not reoccurred after upgrading to 386.9 either.
Of course... re-upgrading to 386.9 and the issue is not repeating. All is well.
Some hints?
Do a factory hard reset. There are a number of threads and posts with people experiencing the same recently.
https://www.snbforums.com/threads/a...t-ac68u-and-rt-ac86u.82209/page-2#post-808255
https://www.snbforums.com/threads/a...ilable-for-ac-models.82796/page-5#post-815701
RMerlin explained the reason/cause for low NVRAM issue post 386.9 update previously in the Beta thread:
Low nvram notification is nothing new, and is becoming increasingly common for that old model as it's running out of nvram space with every new firmware adding new nvram settings. It's part of why Asus is leaving it on the 386 branch most likely, as 388 probably adds even more nvram settings.
This 9 years old model is starting to show its age, with Asus having added lots of new features to it since its initial launch in 2013.
I might have to start considering removing some things from the RT-AC68U to save some nvram space. Reducing the number of OpenVPN clients would be such a thing, as each client consumes around 1 KB of nvram even while not in use.
Some hints?
Before doing a factory reset you may want to try get rid of empty variables in NVRAM:
for line in `nvram show | grep ^[^=]*=$ `; do var=${line%*=}; nvram unset $var; done; nvram commit
It is always good to perform NVRAM dump/backup before in case the script does not work as expected in your env.
This procedure is being mentioned a fair bit. People need to be aware that using this could make their router unstable. Merlin has stated that attempting to change a setting where the variable has been removed from nvram will likely cause a problem.
It should be noted that RMerlin stated the following with respect to running a command like that to erase certain NVRAM variables:
I guess you could try unsetting every vpn_client5_* and vpn_client4_* settings to save some nvram if you don`t use them, however I'm not entirely sure if these wouldn't get recreated at next reboot - I never tested it. It would certainly cause issues if you were to ever try configuring either of these OpenVPN client instances.
Something to be aware of. Generally though any time where are weird issues or memory (RAM, NVRAM, etc.) problems with firmware, the often recommended first step is perform a hard factory reset and then reconfigure manually without importing a previously saved router configuration file. It is also recommended, if one has a USB device attached to the router, to remove that USB device before updating/flashing firmware, and to reconnect that USB device when one has finished manually configuring the router. Further one can try to reduce (a little bit) the NVRAM usage by moving the DHCP manually reserved IP addresses out of NVRAM using YazDHCP or /jffs/configs/dnsmasq.conf.add (with the IP addresses properly configured). Note: Using methods like YazDHCP or dnsmasq.conf.add do have a few limitations, particularly the inability to save/import custom client icons.
The "Enable WAN down browser redirect notice" option is broken in 386.9.
Reproduce:
In Administration -> System > turn off Enable WAN down browser redirect notice
In Parental Controls -> Time Scheduling -> Add a device
In System Log -> Port Forwarding you will see that the forwarding rules used for redirection still exist.
In previous versions, when redirection was turned off, any WAN outage would not be redirected to the router's warning page.
Oh how I wish before I did the factory reset on my RT-AC66U-B1 I'd come across this gem of a guide to NVRAM in the FAQ, written by @RMerlin. Using SSH to get a text-based backup of the NVRAM settings and even saving it to a USB disk sounds very useful. Might be useful to others short on NVRAM going through the chore of a factory reset.
How to I use get a text-based backup?
Connect to your router over SSH/telnet, and run the following:
nvram show | sort
Got back from a vacation with about 40GB drone pictures and videos. Fired up AC86U running Asuswrt-Merlin 386.9, reset it to factory defaults + initialize, mode Media Bridge and WD My Passport to USB 3.0 port. Sort of wireless drive, everything else on default. Got it connected to my APs at full speed 1300Mbps. Result - unable to complete the transfer from 3 attempts. Destination unavailable on my PC in under 10min, out of memory in router logs.
what is the difference between DNS director and DNS Server (Optional) in DHCP Server menu?
DHCP clients can choose to ignore the DNS servers set under LAN - DHCP Server. DNS Director forces them to use a specific DNS server.
Excellent!
Please:
1. Try the same experiment with the official firmware.
2. If 1. also crashes the router, file a report to Asus in the webgui under "Administration/Feedback" - describe what you did in the free-text field, and remember to check "attach logs". This is important, so Asus can scan your log for errors and get to work on a permanent fi that eventually will make its way to Merlin release.
3. If you want to go the extra mile; do the same with another AC86U, so that Asus can exclude (or at least narrow down the probability of) hardware-error as the cause.
The official firmware is months old. This experiment was performed to check if something was fixed in newer base. All Asus routers crash with NAS-like transfers via USB including 1GB RAM models. They just crash a bit later. Tested on AC68U, AC86U, AC5300, AX58U, AX86U, AX88U. USB attached storage is one of advertised, but non-working properly features. If you want to reproduce the issue faster hit the router with thousands of small few KB size files.
Done few times in last two years. No change.
Routers are not NASs — they never will be.
Yes, but the same transfer was completed successfully with no errors on my ISP provided modem/router.
Just wanted to see if Samba is improved in this firmware. Sorry, my mistake.
