Do you see the "Deregister" button on the DDNS page? Try that and re-register again. It's a guess really, I usually change my DDNS host name when this happens...lolI just updated to this beta firmware and everything went succesfully. I got wireguard working as a server and client. Only issue im having is that DDNS wont update. I keep getting this error in my system log. I tried to manually disable ddns and start it again but that didnt work. What should I do?
For IPv4 use the VPN Director page. I don't think IPv6 is supported in this case.Hello. I've installed the latest beta and so far it's been a smooth experience besides one minor inconvenience.
How do you route IPv4 and IPv6 over the Wireguard protocol at the same time?
@RMerlin
I don't know if it is just me, i did even a clean install, i have an axe11000, using beta 1 with asus stock ui not rog.
But the checkbox "Auto select channel including channel 12, 13" does not do anything, after save it just resets to unchecked, and tried all settings combinations possible, cleaned all browser data and forced no cache in browser to make sure everything is updated.
Is this a bug? or just not an option really available any more, or maybe i am making any mistake and should be used in a specific settings combination i didn't get ok.
Thx for your work anyway, everything else is working perfectly.
There are currently no plans to support this model.Will there in the future be support for the AX53U?
cat /proc/net/biqos
It would have been great if it was possible but thanks for the reply.A "dynamic" menu layout is not really possible, and would be a usability nightmare if pages can random change location.
I will test this at some point today.@Lax @blackfireball5
Asus sent me a new version of the fix which re-enables acceleration, but enables/disables it slightly differently.
Can you check this new test build if it's still stable with that new fix when using only AiProtection?
Microsoft OneDrive - Access files anywhere. Create docs with free Office Online.
Store photos and docs online. Access them from any PC, Mac or phone. Create and work together on Word, Excel or PowerPoint documents.1drv.ms
If it runs fine, please provide me with the output from this command:
Code:cat /proc/net/biqos
Thanks.
The AX86U has noticeably less range than the quad antenna AC88U it replaced, so I presume the AX88U as well. Range might be less of an issue if you're running a mesh setup, of course. Just another thing to consider.I've ONE non-WiFi6 capable client that the user will part with when I can pry it "from her cold dead hands," otherwise all of the others (surprisingly) have been ready for almost 2y, so I guess It's time to upgrade the AC86 to one of the Merlin-supported AX series...
must do homework and prepare for Black Friday...but I think it'll be the AX86u (@XIII the 'u' has double the RAM of the 's' version, and a quad core processor vs dual core...and 4 extra ETH ports on the AX88 can be had for less than the price premium over the AX86; AX88 also doesn't have a 2.5GHz port)...eventhough the AX86s will probably still be overkill for my home network.
(when are they gonna make the radios replacable??)
As noted previously in this thread you cannot (or at least no one has worked out how to) run IPv6 through the Wireguard client if you are using VPNDirector. You can however run dual stack if, instead of using VPN Director, you use Wireguard Manager - there are various threads in Addons, but the best starting point is this guide GitHub - ZebMcKayhan/WireguardManager: Manage/Install WireGuard on applicable ASUS routersHello. I've installed the latest beta and so far it's been a smooth experience besides one minor inconvenience.
@skeal That really sucks. I hope they make it a possibility in the near future to at least disable IPv6 on a client basis. I ran into a problem this morning when I routed my PS5 via Wiregaurd Cloudflare.As noted previously in this thread you cannot (or at least no one has worked out how to) run IPv6 through the Wireguard client if you are using VPNDirector. You can however run dual stack if, instead of using VPN Director, you use Wireguard Manager - there are various threads in Addons, but the best starting point is this guide GitHub - ZebMcKayhan/WireguardManager: Manage/Install WireGuard on applicable ASUS routers
Not seeing that here, with the last alpha on my ax88 I'm at 54 degrees after 18 days. It's been running as an openvpn server and uploading about 35mbps to an openvpn client all that time, with one core active at about 10-12%; so stretching its legs but not loaded up.Dirty upgrade from 386.8 all looking very good, only observation is jump in temperatures from
Thanks for your reply.There are currently no plans to support this model.
Thanks.
Yeah, the git tag hasn't changed because there were no new commit since last test build.@RMerlin Actually, I think this is the correct firmware.
That should be the case, yes. So it looks like Asus' new implementation is working properly now.enabled AIProtection and the command is returning "0" meaning it is not being bypassed right?
Welcome To SNBForums
