[Beta 3] Vnstat on Merlin - UI, CLI and email - data use monitoring - now with data limit monitoring
This is going to sound trivial, but is there any way to get the UI to show the date in the UK format. I.E. 7/3/21 (7th March 21) instead of the US method 3/7/21.
Thanks for your hard work.
Explained a few posts above yours.
DayFormat "%d/%m/%y"
MonthFormat "%b '%y"
TopFormat "%d/%m/%y"
Thank you. I guess I missed that!
I edited vnstat.conf according to this ... but I am still getting the old date format after hard refreshing.
Something more to edit?
Ha! I was just about to post the exact same, screen shots too!
I have tried rebooting the router and control-F5
Have you tried to manually generate new images/generate stats?
Yes I have. Interesting, the CLI does show the correct UK format. But the GUI still shows the US format.
According to MAN DATE, the format is %d-%b-%Y for dd-MMM-YYYY.
And once you've edited the conf file, do a "1" update and then a hard refresh.
For clarity, new installs will include the MMM (month) in the date format. We're a supportive bunch!
EDIT: just tested and it works in the UI (%d-%b-%Y).
Thank you, It worked fine.
Editing ...
# date output formats for -d, -m, -t and -w
# see 'man date' for control codes
DayFormat "%d-%b-%Y"
TopFormat "%d-%b-%Y"
I also edited
# title timestamp format
HeaderFormat "%d-%b-%Y %H:%M"
In order to get the yellow date and time according to that.
Strange. Try a reboot. It's working perfectly here
Ah. I added the lines:
Now all is well. Thanks figorr for the suggestion.
Thanks all.
I’m new to command lines, but how can I make the log save to the USB drive instead of memory on the router? I only have 1 USB drive connected.
Hello there. What is this error and how can I fix it? Tell me please.
admin@RT-AX88U-0ВС0:/tmp/home/root# /jffs/scripts/dn-vnstat generateimages
dn-vnstat: vnstati updating stats for UI
vnstati: error while loading shared libraries: libjpeg.so.62: cannot open shared object file: No such file or directory
The default location for the database files is /opt/var/lib/vnstat/ which is actually symlinked to /mnt/your_usb_drive/entware/var/lib/vnstat/. So the dbs are on your usb drive already.
Weird Numbers, any way to "reset" them?
Hmmm, never saw this in any of the testing, except a "doubling" on one import on one test. I'd suggest backing up your db: vnstat --exportdb > /path/to/vnstat-export-db.txt before taking any additional steps.
Can you post or PM what was happening around the time of this discovery and describe your hardware/firmware version, please.
Before you reset, can you run /jffs/scripts/dn-vnstat generatestats and then PM the output of /tmp/vnstat.txt please, and run vnstat -h (hours) and PM me that too, please?
Then you can reset the database by running vnstat -r (or vnstat --reset).
This looks like a missing application/dependency (for the imagemagick component). Can you describe the device and firmware version please. You may also try to re-run the CLI full install command (it won't delete any data files) to see if that helps.
Device ASUS RT-AX88U firmware Asus Merlin 386.1_2. Re-installing the CLI did not give a result. Deleted opkg remove imagemagick --autoremove, opkg remove vnstat --autoremove, opkg remove vnstati --autoremove rebooted the device and installed it in a new way did not help. Another error when generating statistics via amtm in the screenshot.
convert: UnableToLoadModule '/tmp/mnt/app/entware/lib/ImageMagick-7.0.9/modules-Q8/coders/png.la': file not found @ error/module.c/OpenModule/1287.
convert: NoEncodeDelegateForThisImageFormat `LABEL' @ error/constitute.c/WriteImage/1222.
See, posts 24, 25 & 34 For issue I had and Jack Yaz response to a log I sent him. Other than reinstalling back then (I think 3/3 or 3/4), when I upgraded to AMTM, there was an upgrade in amtm to 0.9.4 even though I was already on 0.9.4, but I said update anyhow (through amtm).
I will attempt to get the info you asked for and get back to you through posts here or PM (depending on how long the data is when I run it --I'll try now, hopefully I can get it).
Edit: RT-AC86U 386.1_2
@dev_null
version;3
active;1
interface;eth0
nick;eth0
created;1614571993
updated;1615213801
totalrx;17592186380733
totaltx;19590
currx;182924857344
curtx;7335038976
totalrxk;169
totaltxk;155
btime;1615065263
d;0;1615179633;12801;808;243;125;1
d;1;1615093223;20461;1983;533;388;1
d;2;1615006854;160354;5325;800;463;1
d;3;1614920444;36142;1843;230;333;1
d;4;1614834035;20613;890;137;237;1
d;5;1614747639;19479;1437;828;930;1
d;6;1614661226;37752;1702;1019;358;1
d;7;1614574816;17592186072344;5570;624;490;1
d;8;1614571993;782;28;875;927;1
d;9;0;0;0;0;0;0
d;10;0;0;0;0;0;0
d;11;0;0;0;0;0;0
d;12;0;0;0;0;0;0
d;13;0;0;0;0;0;0
d;14;0;0;0;0;0;0
d;15;0;0;0;0;0;0
d;16;0;0;0;0;0;0
d;17;0;0;0;0;0;0
d;18;0;0;0;0;0;0
d;19;0;0;0;0;0;0
d;20;0;0;0;0;0;0
d;21;0;0;0;0;0;0
d;22;0;0;0;0;0;0
d;23;0;0;0;0;0;0
d;24;0;0;0;0;0;0
d;25;0;0;0;0;0;0
d;26;0;0;0;0;0;0
d;27;0;0;0;0;0;0
d;28;0;0;0;0;0;0
d;29;0;0;0;0;0;0
m;0;1614574816;17592186379950;19561;318;252;1
m;1;1614571993;782;28;875;927;1
m;2;0;0;0;0;0;0
m;3;0;0;0;0;0;0
m;4;0;0;0;0;0;0
m;5;0;0;0;0;0;0
m;6;0;0;0;0;0;0
m;7;0;0;0;0;0;0
m;8;0;0;0;0;0;0
m;9;0;0;0;0;0;0
m;10;0;0;0;0;0;0
m;11;0;0;0;0;0;0
t;0;1614574816;17592186072344;5570;624;490;1
t;1;1615006854;160354;5325;800;463;1
t;2;1614661226;37752;1702;1019;358;1
t;3;1614920444;36142;1843;230;333;1
t;4;1615093223;20461;1983;533;388;1
t;5;1614834035;20613;890;137;237;1
t;6;1614747639;19479;1437;828;930;1
t;7;1614571993;782;28;875;927;1
t;8;0;0;0;0;0;0
t;9;0;0;0;0;0;0
h;0;1615183176;1863391;72191
h;1;1615186779;1982458;42982
h;2;1615190382;1437954;37565
h;3;1615193985;1495367;60841
h;4;1615197588;1554492;363099
h;5;1615201191;1957976;121323
h;6;1615204794;1137085;49066
h;7;1615208397;584680;29334
h;8;1615211940;842836;34210
h;9;1615213801;252228;16906
h;10;1615132795;835619;283217
h;11;1615136398;857037;224615
h;12;1615139941;769138;264105
h;13;1615143543;690573;136226
h;14;1615147146;656915;28251
h;15;1615150749;539347;26595
h;16;1615154352;702181;29449
h;17;1615157955;738322;30812
h;18;1615161558;529037;30314
h;19;1615165161;1782337;69243
h;20;1615168764;694971;37523
h;21;1615172367;566828;28673
h;22;1615175970;608533;32237
h;23;1615179573;671085;35772
vnstat.txt
vnstats as of:
Mon Mar  8 09:32:04 EST 2021
eth0  /  monthly
    month        rx      |     tx      |    total
   Feb '21     782.85 MB |    28.91 MB |   811.76 MB
   Mar '21   16,777,216.00 TB |    19.10 GB | 16,777,216.00 TB
estimated  68,382,976.00 TB |    77.86 GB | 68,382,976.00 TB
eth0  /  weekly
                   rx      |     tx      |    total
last 7 days     300.40 GB |    13.66 GB |   314.06 GB
   last week   16,777,216.00 TB |    18.31 GB | 16,777,216.00 TB
current week      12.50 GB |   808.16 MB |    13.29 GB
   estimated     233.35 GB |    14.73 GB |   248.08 GB
eth0  /  daily
     day         rx      |     tx      |    total
02/28/2021    782.85 MB |    28.91 MB |   811.76 MB
03/01/2021  16,777,216.00 TB |     5.44 GB | 16,777,216.00 TB
03/02/2021     36.87 GB |     1.66 GB |    38.53 GB
03/03/2021     19.02 GB |     1.40 GB |    20.43 GB
03/04/2021     20.13 GB |   890.23 MB |    21.00 GB
03/05/2021     35.30 GB |     1.80 GB |    37.10 GB
03/06/2021    156.60 GB |     5.20 GB |   161.80 GB
03/07/2021     19.98 GB |     1.94 GB |    21.92 GB
03/08/2021     12.50 GB |   808.16 MB |    13.29 GB
estimated      31.47 GB |     1.99 GB |    33.46 GB
vnstat -h
 eth0        09:37
  ^                                               r
  |                                            r  r           r
  |                             r              r  r           r
  |                             r              r  r  r  r  r  r
  |                             r              r  r  r  r  r  r
  |                             r              r  r  r  r  r  r  r
  |  r  r                       r              r  r  r  r  r  r  r     r
  |  r  r  r  r  r     r  r     r  r     r  r  r  r  r  r  r  r  r     r
  |  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  r
  |  rt rt rt r  r  r  r  r  r  r  r  r  r  r  r  r  r  r  rt r  r  r  r  r
  |  10 11 12 13 14 15 16 17 18 19 20 21 22 23 00 01 02 03 04 05 06 07 08 09
h  rx (MiB)   tx (MiB)  ][  h  rx (MiB)   tx (MiB)  ][  h  rx (MiB)   tx (MiB)
10      816.0      276.6 ][ 18      516.6       29.6 ][ 02    1,404.3       36.7
11      837.0      219.4 ][ 19    1,740.6       67.6 ][ 03    1,460.3       59.4
12      751.1      257.9 ][ 20      678.7       36.6 ][ 04    1,518.1      354.6
13      674.4      133.0 ][ 21      553.5       28.0 ][ 05    1,912.1      118.5
14      641.5       27.6 ][ 22      594.3       31.5 ][ 06    1,110.4       47.9
15      526.7       26.0 ][ 23      655.4       34.9 ][ 07      571.0       28.6
16      685.7       28.8 ][ 00    1,819.7       70.5 ][ 08      823.1       33.4
17      721.0       30.1 ][ 01    1,936.0       42.0 ][ 09      247.7       17.1
NOTE: I have not reset. I'll wait in case you need something else
@dev_null
version;3
active;1
interface;eth0
nick;eth0
created;1614571993
updated;1615213801
totaltx;19590
currx;182924857344
curtx;7335038976
totalrxk;169
totaltxk;155
btime;1615065263
d;9;0;0;0;0;0;0
d;10;0;0;0;0;0;0
d;11;0;0;0;0;0;0
d;12;0;0;0;0;0;0
d;13;0;0;0;0;0;0
d;14;0;0;0;0;0;0
d;15;0;0;0;0;0;0
d;16;0;0;0;0;0;0
d;17;0;0;0;0;0;0
d;18;0;0;0;0;0;0
d;19;0;0;0;0;0;0
d;20;0;0;0;0;0;0
d;21;0;0;0;0;0;0
d;22;0;0;0;0;0;0
d;23;0;0;0;0;0;0
d;24;0;0;0;0;0;0
d;25;0;0;0;0;0;0
d;26;0;0;0;0;0;0
d;27;0;0;0;0;0;0
d;28;0;0;0;0;0;0
d;29;0;0;0;0;0;0
m;2;0;0;0;0;0;0
m;3;0;0;0;0;0;0
m;4;0;0;0;0;0;0
m;5;0;0;0;0;0;0
m;6;0;0;0;0;0;0
m;7;0;0;0;0;0;0
m;8;0;0;0;0;0;0
m;9;0;0;0;0;0;0
m;10;0;0;0;0;0;0
m;11;0;0;0;0;0;0
t;8;0;0;0;0;0;0
t;9;0;0;0;0;0;0
vnstat.txt
vnstats as of:
eth0  /  monthly
eth0  /  weekly
                   rx      |     tx      |    total
eth0  /  daily
     day         rx      |     tx      |    total
vnstat -h
 eth0        09:37
  ^                                               r
  |                                            r  r           r
  |                             r              r  r           r
  |                             r              r  r  r  r  r  r
  |                             r              r  r  r  r  r  r
  |                             r              r  r  r  r  r  r  r
It looks as some Nan converted to string - it is similar to something like MAX_INT constant ....
