[Beta 3] Vnstat on Merlin - UI, CLI and email - data use monitoring - now with data limit monitoring
can you post a copy please? :)
Sorry, yes :)
ok thats a bug then. we test for Gb/GiB at the moment. you're in the TB range....fix incoming
I thought that, you we're only comparing GB/GiB...
Future-proof it and prepare it for PB and so on (I think Mb isn't really necessary?) :p
PB seems unnecessary too at the moment (famous last words) so I haven't added support for it.
a much longer "10-15" than I thought, but some changes up on develop that should handle TB properly...I've /only/ used 700GB so cant test
Another 10-15 is enough? :)
Hi all
How many rows is daily usage configured for ? Is this configurable?
Hi all
30. In theory it's selectable, but the commands don't work with the current Entware version (1.18) of vnstat (for example, if you read the online help, it indicates vnstat -d 10 should show 10 days, but it doesn't seem to work. I'm hopeful for the 2.x branch to be included in Entware sometime soon.)
found a lot of "TB" statistics? how to correct it?
