New firmware is out!
ASUS RT-AC68U Firmware version 3.0.0.4.374.542
Fixes
1. Fixed the CTF lock handling mechanism.
2. Updated the descriptions in WDS page.
3. Updated the descriptions in VPN client and Time Machine pages.
4. Fixed the USB modem connection issue in load balance mode
Not for Widows 7.
Yes it is, I downloaded for Win7 64bit.
Could you write the download link? The Asus site only shows the old beta 501 firmware.
Not for Widows 7.
That's odd, since I haven't done any change to minidlna. In fact the one patch I have applied to it was sent to Asus, which applied it to theirs a few weeks ago. Might be something else that's different (I do use a much newer version of the uPNP daemon for instance).
rmerlin,
i know the thread is old and there is probably a better place to ask this but I was curious as to how much newer version of uPNP daemon and what the major benefits are? Might be pretty stupid but I'm trying to get my xbox to run just as well through this router as it does straight from the modem. I have done portforwarding, static ip address (through xbox and with mac assigning in router), upnp off/on, dmz, etc. and every combination of all of those. I havent achieved sustainable results. Some setups worked well for 30 mins or so but then would become degraded and needed a reboot. I decided finding the best upnp would prob be the best way to go since even dmz'ing the xbox didn't work out for very long. I remembered seeing your post about having a much more updated upnp but I am not really sure what all that entails. I was going to move to your FW eventually after it was out of beta (i think it still is in beta right but Ill check that after i finish this post), but wanted some more info on upnp daemon as well.
Welcome To SNBForums
