[BETA] Asuswrt-Merlin 380.59 Beta 1 is now available
I get the following error when trying to update to the latest beta on my AC66(R). I've tried redownloading from the mirror to make sure it wasn't a corrupted download.
The traffic analyzer statistic continues to be incorrect in the daily chart
I notice that as well but it appears that what it shows in the chart itself is correct as the apps do change when selecting daily/weekly/monthly.
Yeah, I've been running Asuswrt-Merlin on my router for the past couple of years so this isn't my first update. Been a long-time lurker and just finally created a username today :)
Welcome aboard!
Can you check the sha256sum.txt against the .trx file to see if it arrives safely for you?
I just tested it here and it checks out fine with the SHA256 hash.
There was an AC66U build of 380.58; did that not use Asus GPL 380_1354?
I was patching things together to make the AC66U build with the 380 GPL, it wasn't official code.
Welcome aboard!
Yep - the hash of my trx file matches the text file. This is the first time I've ever encountered this particular error with the firmware (beta or otherwise).
In the DHCP static lease page, there are a lot of devices named "new device", it does not take the hostname, which instead is correct
This is how Asus's networkmap code was implemented by them - if you add a device and it doesn't have any assigned name on the networkmap, then it defaults to "New device". Keep in mind that the networkmap description and the DHCP hostname are two separate fields.
Where does the Trend Micro statistics store its information?
JFFS partition. /jffs/traffic.db.
Traffic Analyzer is mostly closed source, and its webui is quite confusing to use - I've never really fully understood how it was supposed to work.
In my case, just CTF is being shown as enabled. It used to show CTF+FA until I turned it off after enabling the Statistics deal. Note: with CTF enabled, the Statistics does seem correct as it matches when acceleration is off. Originally when it showed CTF+FA, the statistics was not correct. I had to disable it. Then I re-enabled it and just CTF showed. Strange.
I think Asus recently said that FA was being removed due to its numerous compatibility/stability issues, so whatever is shown on the webui related to FA should be taken with a grain of salt.
Reboot your router while not having any USB disk plugged in to free up enough RAM to complete the upgrade.
I don't have any USB disks plugged into it, but the reboot did the trick! Weird, I've never had to do that before, but whatever works :) !
Thanks so much for all of your work on keeping our routers at the cutting edge!
Just flashed 380.59 B1 on my AC-3100 and all is good thanks Eric. :)
Hi everyone and first of all thx for your hard work Eric.
I made a big jump today on my AC68U - from 378.56_2 to 380.59 beta1 - all seems ok except my usb3.0 downgraded to usb2.0 (3TB wd red in lc-power lc-35u3 case, 1 partition ext4, upgrade procedure: unplug usb, restart, upgrade, factory default, manual config)
But i think is more Asus related.
02:00:24 kernel: Initializing USB Mass Storage driver...
02:00:24 kernel: usbcore: registered new interface driver usb-storage
02:00:24 kernel: USB Mass Storage support registered.
02:00:25 kernel: Tuxera FAT 12/16/32 driver version 3015.1.29.5_1 [Flags: R/W MODULE].
02:00:25 kernel: Built against headers 2.6.36.4brcmarm #1 SMP PREEMPT Wed Dec 2 11:17:39 CST 2015 arm
02:00:25 kernel: Running on kernel 2.6.36.4brcmarm #2 SMP PREEMPT Sun Apr 24 13:28:44 EDT 2016 armv7l
02:00:25 kernel: Tuxera NTFS driver 3015.1.29.8_1 [Flags: R/W MODULE].
02:00:25 kernel: Tuxera HFS+ driver 3014.7.28
02:00:25 kernel: xhci_hcd 0000:00:0b.0: xHCI Host Controller
02:00:25 kernel: xhci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 1
02:00:25 kernel: xhci_hcd 0000:00:0b.0: irq 112, io mem 0x18023000
02:00:25 kernel: xhci_hcd 0000:00:0b.0: Failed to enable MSI-X
02:00:25 kernel: xhci_hcd 0000:00:0b.0: failed to allocate MSI entry
02:00:25 kernel: usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
02:00:25 kernel: hub 1-0:1.0: USB hub found
02:00:25 kernel: hub 1-0:1.0: 1 port detected
02:00:25 kernel: [xhci-hub] usb2mode:[0]
02:00:25 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
02:00:25 kernel: ehci_hcd 0000:00:0a.1: EHCI Host Controller
02:00:25 kernel: ehci_hcd 0000:00:0a.1: new USB bus registered, assigned bus number 2
02:00:25 kernel: ehci_hcd 0000:00:0a.1: irq 111, io mem 0x18021000
02:00:25 kernel: hub 1-0:1.0: over-current change on port 1
02:00:25 kernel: ehci_hcd 0000:00:0a.1: USB 0.0 started, EHCI 1.00
02:00:25 kernel: hub 2-0:1.0: USB hub found
02:00:25 kernel: hub 2-0:1.0: 2 ports detected
02:00:25 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
02:00:25 kernel: ohci_hcd 0000:00:0a.0: OHCI Host Controller
02:00:25 kernel: ohci_hcd 0000:00:0a.0: new USB bus registered, assigned bus number 3
02:00:25 kernel: ohci_hcd 0000:00:0a.0: irq 111, io mem 0x18022000
02:00:25 kernel: hub 3-0:1.0: USB hub found
02:00:25 kernel: hub 3-0:1.0: 2 ports detected
02:00:25 kernel: hub 2-0:1.0: over-current change on port 1
02:00:25 kernel: usbcore: registered new interface driver usblp
02:00:25 kernel: hub 2-0:1.0: over-current change on port 2
02:00:25 kernel: usbcore: registered new interface driver asix
02:00:25 kernel: usbcore: registered new interface driver cdc_ether
02:00:25 kernel: usbcore: registered new interface driver rndis_host
02:00:25 kernel: cdc_ncm: 14-Mar-2012
02:00:25 kernel: usbcore: registered new interface driver cdc_ncm
02:00:25 kernel: usbcore: registered new interface driver cdc_wdm
02:00:25 kernel: usbcore: registered new interface driver qmi_wwan
02:00:25 kernel: cdc_mbim: loaded
02:00:25 kernel: usbcore: registered new interface driver cdc_mbim
02:00:26 kernel: hub 2-0:1.0: over-current change on port 1
02:00:26 kernel: usb 2-1: new high speed USB device using ehci_hcd and address 2
02:00:27 kernel: scsi0 : usb-storage 2-1:1.0
02:00:27 kernel: hub 2-0:1.0: over-current change on port 2
02:00:27 kernel: hub 1-0:1.0: over-current change on port 1
02:00:27 kernel: [xhci-hub] usb2mode:[0]
02:00:29 kernel: scsi 0:0:0:0: Direct-Access ATA WDC WD30EFRX-68E 0A80 PQ: 0 ANSI: 6
02:00:29 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
02:00:29 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
02:00:29 kernel: sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
02:00:29 kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
02:00:29 kernel: sd 0:0:0:0: [sda] Write Protect is off
02:00:29 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
02:00:36 kernel: sda: sda1
02:00:36 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
02:00:36 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
02:00:36 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
02:00:36 hotplug[668]: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/TeraByt
02:00:36 usb: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/TeraByt.
02:00:36 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr
02:00:22 kernel: Initializing USB Mass Storage driver...
02:00:22 kernel: usbcore: registered new interface driver usb-storage
02:00:22 kernel: USB Mass Storage support registered.
02:00:23 kernel: Tuxera FAT 12/16/32 driver version 3015.1.29 [Flags: R/W MODULE].
02:00:23 kernel: Built against headers 2.6.36.4brcmarm #1 SMP PREEMPT Tue May 19 11:31:15 CST 2015 arm
02:00:23 kernel: Running on kernel 2.6.36.4brcmarm #1 SMP PREEMPT Mon Nov 2 10:07:03 EST 2015 armv7l
02:00:23 kernel: Tuxera NTFS driver 3015.1.29 [Flags: R/W MODULE].
02:00:23 kernel: Tuxera HFS+ driver 3014.7.28
02:00:23 kernel: xhci_hcd 0000:00:0b.0: xHCI Host Controller
02:00:23 kernel: xhci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 1
02:00:23 kernel: xhci_hcd 0000:00:0b.0: irq 112, io mem 0x18023000
02:00:23 kernel: xhci_hcd 0000:00:0b.0: Failed to enable MSI-X
02:00:23 kernel: xhci_hcd 0000:00:0b.0: failed to allocate MSI entry
02:00:23 kernel: usb usb1: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
02:00:23 kernel: hub 1-0:1.0: USB hub found
02:00:23 kernel: hub 1-0:1.0: 1 port detected
02:00:23 kernel: [xhci-hub] usb2mode:[0]
02:00:23 kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
02:00:23 kernel: ehci_hcd 0000:00:0a.1: EHCI Host Controller
02:00:23 kernel: ehci_hcd 0000:00:0a.1: new USB bus registered, assigned bus number 2
02:00:23 kernel: ehci_hcd 0000:00:0a.1: irq 111, io mem 0x18021000
02:00:23 kernel: ehci_hcd 0000:00:0a.1: USB 0.0 started, EHCI 1.00
02:00:23 kernel: hub 2-0:1.0: USB hub found
02:00:23 kernel: hub 2-0:1.0: 2 ports detected
02:00:23 kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
02:00:23 kernel: ohci_hcd 0000:00:0a.0: OHCI Host Controller
02:00:23 kernel: ohci_hcd 0000:00:0a.0: new USB bus registered, assigned bus number 3
02:00:23 kernel: ohci_hcd 0000:00:0a.0: irq 111, io mem 0x18022000
02:00:23 kernel: usb 1-1: new SuperSpeed USB device using xhci_hcd and address 2
02:00:23 kernel: xhci_hcd 0000:00:0b.0: WARN: short transfer on control ep
02:00:23 kernel: hub 3-0:1.0: USB hub found
02:00:23 kernel: hub 3-0:1.0: 2 ports detected
02:00:23 kernel: xhci_hcd 0000:00:0b.0: disable burst on ep 1
02:00:23 kernel: xhci_hcd 0000:00:0b.0: WARN no SS endpoint bMaxBurst
02:00:23 kernel: xhci_hcd 0000:00:0b.0: disable burst on ep 2
02:00:23 kernel: scsi0 : usb-storage 1-1:1.0
02:00:23 kernel: usbcore: registered new interface driver usblp
02:00:24 kernel: usbcore: registered new interface driver asix
02:00:24 kernel: usbcore: registered new interface driver cdc_ether
02:00:24 kernel: usbcore: registered new interface driver rndis_host
02:00:24 kernel: cdc_ncm: 14-Mar-2012
02:00:24 kernel: usbcore: registered new interface driver cdc_ncm
02:00:24 kernel: usbcore: registered new interface driver cdc_wdm
02:00:24 kernel: usbcore: registered new interface driver qmi_wwan
02:00:24 kernel: cdc_mbim: loaded
02:00:24 kernel: usbcore: registered new interface driver cdc_mbim
02:00:26 kernel: scsi 0:0:0:0: Direct-Access ATA WDC WD30EFRX-68E 0A80 PQ: 0 ANSI: 6
02:00:26 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
02:00:26 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
02:00:26 kernel: sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
02:00:26 kernel: sd 0:0:0:0: [sda] 4096-byte physical blocks
02:00:26 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
02:00:26 kernel: sd 0:0:0:0: [sda] Write Protect is off
02:00:26 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
02:00:33 kernel: sda: sda1
02:00:33 kernel: sd 0:0:0:0: [sda] Very big device. Trying to use READ CAPACITY(16).
02:00:33 kernel: xhci_hcd 0000:00:0b.0: WARN: Stalled endpoint
02:00:33 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
02:00:33 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
02:00:33 kernel: nf_conntrack_rtsp v0.6.21 loading
02:00:33 kernel: nf_nat_rtsp v0.6.21 loading
02:00:33 hotplug[664]: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/TeraByt
02:00:33 usb: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/TeraByt.
02:00:33 kernel: EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: user_xattr
68U, the 1GHZ one. GUI flakey, LAN device list shows blank, then all of my clients, then blank again. Then its locked up and needs a power off boot.
Going back to previous non-beta version.
Edit: Well now I don't know. While digging around to find the previous FW to upload, which took some time, the LAN listing stuff seems to have settled down. Maybe it needed some time to refresh and update to the new way of listing things?
I left it be for now. If any hiccup will go back to previous FW.....
