[Beta] Asuswrt-Merlin 384.10 Beta is now available
My self-compiled 384.10_b2 has been up and running 4 days now. Excellent build, @RMerlin !
For what it’s worth,
I have native IPv6, dns filter (blank, refer to router for dns), require strict DNSSEC validation, manually define dns (including Cloudflare), & have for a long while had my log levels set to ‘warning’.
Everything just works, no junk seen in logs......
I'm unable to locate the filter fields. FYI.
Just an FYI, still getting hundreds of these in the log. They don't seem to be affecting operation of the router. The dnsmasq seems to be a set of 3 varying numbers-317, 321, or 325:
Mar 14 22:47:45 dnsmasq[317]: failed to send packet: Operation not permitted
RT AC-5300
I am getting the same as you on the last release and hoping it would be fixed on this one. I am using the AC88U and even did a fresh flash and manually entering the settings and the issue still exists. It causes issues with my streams. I am using openDNS and have manual DNS settings. There have been a few with this issue and not sure if it's being passed to this release. My number this time is 313 but changes.
384.10 Beta 2 is now available.
Exceptionally, beta 2 does come with some new features, notably the reworked Classification page. In addition to performance improvements, you can now filter the list in real-time by entering part of a string in any of the filter fields (you can even filter two fields at a time). Also some extra info is now shown when hovering entry fields.
mainline:
0949acc4e3 Updated documentation
bee21ea139 webui: apply Classification filter after IPv6 have been compressed, so the filter gets applied to the displayed version
0968d34c83 Updated documentation
03881a1621 webui: implemented filtering to the Classification page; fixed typo in current_page parameter
54755feb1c webui: Re-implemented tracked connections table without using a Table object
29d312caa6 shared: moved dns_local setting to the section with other Merlin-specific settings
2b4fff3cd2 www/rc: make using dnsmasq as system resolver optional
840dcda2c6 webui: let the Ajax call handle the first chart/table rendering; also bump auto-refresh threshold to 500 entries
a1d5949863 strongswan: remove 5.2.1 leftovers
61eda56fdf minidlna: added gitignore
b52368af9d nano: updated gitignore
45cd22f190 strongswan: added gitignore
e98bc01433 wget: updated gitignore
df7bed4afd Bumped revision to beta 2
efeb6c12eb Updated documentation
7ea734eaa6 pppd: implement lcp-ident option
8225488882 nfs-utils-1.3.4: fix rebuild after clean
c12629a30e libmnl: fix rebuild after clean
9a5c206f4f rp-pppoe: relay: fix crash
2938a77cbe pppd: pppoe-plugin,rp-pppoe: fix host-uniq option support
5670357618 pppd: pppoe-plugin,rp-pppoe: switch to monotonic time
045849eb50 pppd: switch to monotonic time
62b42d629b pppd: fix warning w/o IPv6
67090e2b67 pppd: add support for custom pap-secrets file location
05f8d80d81 dnsmasq: update to 2.80-44-g608aa9f
7cf798767a avahi: recover .gitignore files
fd2195411c rc: rework dns stub
fd486d5c00 openssl11: recover missed files from 1.1.1b
3f40055e12 openssl11: add gitignore to the tree
ab29470364 openssl11: remove temp file accidentally included in commit
c7b584c3f4 (tag: 384.10-beta1) Updated documentation
rt88ax:
08e73a90d9 lighttpd: fix location of modules on HND-AX
In addition to the details mentioned in the first post, please test the revamped Classification page as well.
Regarding the error messages generated by dnsmasq under IPv6: there are no new development. I am still unable to reproduce the issue, and I have no idea what is triggering it. I suspect it has to do with a recent change in dnsmasq. I might end up just moving the error message to debug priority for the final release for the time being.
@RMerlin , dirty upgrade over beta1...., Everything running great so far. Running openVPN, diversion, amtm, skynet and I'm running @FreshJR 's mod which I assume loads over your classification page if I read it correctly. If thats the case I would assume I wouldn't notice the changes you made to yours as it gets overwritten or mounted over?
Where before I was seeing around 775Mbps on upload, I just got a speed of 945Mbps. The first CPU core was pegged at around 97%, but this is a huge improvement.
There has been absolutely no change related to network performance in beta 2...
The 384_5640 merge for RT-AX88U looked pretty straightforward (aside from a small piece of code that was missing from my GPL tarball, and which I had to extrapolate), so I did a test build with that GPL merged in. Please give it a try, and if all goes well, I might include it in the 384.10 final release.
https://asuswrt.lostrealm.ca/test-builds
Thanks for posting this, still getting extremely high performance for uploads unless others report something similar it may just be my ISP that changed something on their end.
mainline:
rt88ax:
Just to let you know.. The log spam also happens on last Asus stable build release in December.. Older Asus stable build don't have such log spam.
Sent from my Pixel 2 XL using Tapatalk
All good here on 384.10_beta2 RT-AC87u
Hi
On 384.8_2, have not updated to 384.9 as I'm going to wait for 384.10 and do a reset.
Has the dcd crashes been fixed in the 384.10 ?
Hi
No, that's a ASUS problem. Merlin can't fix that issue.
Hi
No. That would require new GPL drops from ASUS -- the latest for the 86U is from early December.
Noticed following two changes for good on my ax88u after upgrading to 384.10 Beta 2.
1) System logs not reporting annoying logs WLCEVENTD: ASSOC & DISSOC that I was seeing every other second.
2) Considerable drop in CPU temp with about same amount of client connection than it was with previous version 384.9. It's staying around 66-67 whereas it would always be 72 and even goes over 75 few times. Obviously, rise and fall in CPU temp depend on the client connections, but still felt it shouldn't have been that high as it was.
Good to see its not happening anymore with build 384.10. Looking forward for the next one.
Upgraded to beta 2 last night. This morning noticed attempted connections to VPN in the log. That is strange as I change the default port which stops that kind of probe. Checking the OpenVPN settings showed they had all gone back to default. I checked the profile I had used to successfully test beta 1 with yesterday and it showed the setting values I had changed including the port.
Something in the upgrade to beta 2 mess up the VPN settings? All else seems ok.
Sent from my SM-T380 using Tapatalk
Edit: Ah, disregard the above. Seems that I had reset OpenVPN to default yesterday. Call that operator error or being rushed to go out on a shopping adventure... VPN did work well with the defaults.
Updated to 384.10_beta2_5640 No problems
I'm using the new test build for the ax88u and I still cannot set the wifi 5g channel to auto. If I do none of my devices can see the 5g network. If I select a channel there is no issue. Wifi will not work also with the new HE frames selected and or enabling the 160MHz channels as well. I'm petty sure this is a known issue but it was not addressed in the new build. I also have no sort bar as shown in the picture in first post. I have the same filter by bar and a drop down that lists all connected devices. No other issues at this point to report. Thanks for the Test Build Eric!
Try these settings;
