[Beta] Asuswrt-Merlin 384.11 Beta is now available
RT-ac68u , 384.11b2 Firmware. Same thing
traceroute to www.ebay.com (23.40.73.213), 30 hops max, 60 byte packets
 1  122.58.252.1 (122.58.252.1)  -1556866049456.128 ms  -1556866049457.553 ms  -1556866049456.087 ms
 2  * * *
 3  122.56.116.5 (122.56.116.5)  -1556866049456.331 ms  -1556866049456.398 ms  -1556866049456.514 ms
 4  122.56.127.17 (122.56.127.17)  -1556866049456.471 ms  -1556866049456.568 ms 122.56.119.53 (122.56.119.53)  -1556866049456.645 ms
 5  202.50.232.234 (202.50.232.234)  -1556866049686.103 ms 202.50.232.182 (202.50.232.182)  -1556866049569.179 ms 202.50.232.242 (202.50.232.242)  -1556866049618.323 ms
 6  122.56.119.86 (122.56.119.86)  -1556866049568.163 ms  -1556866049524.284 ms  -1556866049521.497 ms
 7  45.127.172.102 (45.127.172.102)  -1556866049502.916 ms  31.672 ms  -1556866049496.379 ms
 8  * * *
 9  * * *
10  * * *
11  * * *
12  * * *
13  * * *
14  * * *
15  * * *
16  * * *
17  * * *
18  * * *
19  * * *
20  * * *
21  * * *
22  * * *
23  * * *
24  * * *
25  * * *
26  * * *
27  * * *
28  * * *
29  * * *
30  * * *
Traceroute on RT-ac86u shows...
traceroute to www.ebay.com (23.35.181.189), 30 hops max, 60 byte packets
1 10.128.128.1 (10.128.128.1) 11.978 ms 11.640 ms 11.695 ms
2 100.127.76.44 (100.127.76.44) 14.772 ms 14.741 ms 14.574 ms
3 100.120.100.24 (100.120.100.24) 14.650 ms 14.629 ms 14.596 ms
4 langbprj02-ae1.0.rd.la.cox.net (68.1.1.14) 24.168 ms 24.276 ms 24.246 ms
5 ae-6.r01.lsanca20.us.bb.gin.ntt.net (168.143.229.57) 24.895 ms 24.212 ms 24.208 ms
6 ae-1.akamai-onnet.lsanca20.us.bb.gin.ntt.net (140.174.28.58) 94.815 ms 83.976 ms 94.151 ms
7 ae2.ctl-lax4.netarch.akamai.com (23.203.155.180) 31.572 ms 28.136 ms 28.166 ms
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Not sure if hnd and non-hnd routers have a different issue? I'm using self compiled 381.11_beta3. Not seeing any issues that stand out.
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
Where did you get 381.11 Beta 3? :)
It could be the DNSFILTER setting that is effecting the behavior. What do you have it set to?
I dont use DNS Filter (never used it). Settings were: 1 VPN client for your test in different scenario's as requested. At the time of testing my running scripts were: Latest versions of AMTM, Diversion, Skynet, Pixelserver and Entware. Nothing more then that. Hope it helps?
That traceroute is perfectly normal, it's simply that eBay does not respond to ICMPs.
Is there a reason that IPTV settings don't get loaded until the end of the boot up process? In my case it would be beneficial to load as early as it could. Nice work Eric!
EDIT: Added a screenshot.
I think I've got everything setup correctly.
I did notice when you select "Cleanbrowsing 2 (family)" from the preset list, it's the same address as "Cleanbrowsing 2 (family). I think it should be 185.228.169.168
The mainline branch is not yet merge with the B3, and the Master branch which is with B3, is not yet MERGE in the Mainline for the Ac86
How did you do that, from what commit did you build?
Are you sure you do not have build on the Master branch? Last commit on Mainline is b043583 ( 3 days old ).I made a git pull this morning on the Mainline and nothing have change since 3 days( same commit)
https://github.com/RMerl/asuswrt-merlin.ng/commits/mainline
https://github.com/RMerl/asuswrt-merlin.ng/commits/master
Its just I do not see the interest of build on the Master Branch for the Ac86, that it does not include the GPL 45713 on this one, or maybe I'm missing something :)
New graph in section "network analasys" is so cool !
You notice that the master commit is always ahead. I alternate between master and mainline. Used to have issues in the past compiling from master. I'm using the rsync method that @RMerlin posted elsewhere in the forums. If you need more proof, I can post the ssh line. Is this proof enough? ASUSWRT-Merlin RT-AC86U 384.11-beta3 Fri May 3 21:30:17 UTC 2019
I think someone said that they lost connectivity to the gui via http. The same thing happened to me this morning on beta2 with my AC86U. I was able to log in by https, and after rebooting the router, access via http worked again.
Happens a lot. Easier to ssh into the router and "service restart_httpd". Or install Jack Yaz's scMerlin (https://www.snbforums.com/threads/scmerlin-service-and-script-control-menu-for-asuswrt-merlin.56277/) and you can use that to restart httpd.
