Release [Beta] Asuswrt-Merlin 384.19 beta is now available
Installed Beta 1 on AX58 and running well. Have a few errors in the log that appear everyday. Anything to consider?
Aug 9 03:04:00 kernel: plcp 000e 0000 || 01cb 0000 0000 || 0000 0000 || 00
Aug 9 03:04:00 kernel: txbyte 0000 0000 unflsts 1ad0 usr 0000
Aug 9 03:04:30 kernel: txerr mac 0300 phy a680 0000 2200 tst 2531 dur 000c
Aug 9 03:04:30 kernel: pctlen 0014 pctls 0b41 0000 0003 0000 0000 0000
Aug 9 03:04:30 kernel: plcp 000e 0000 || 01cb 0000 0000 || 0000 0000 || 00
Aug 9 03:04:30 kernel: txbyte 0000 0000 unflsts 1ad0 usr 0000
Installed 19_beta1 on two MESH systems:
1. AC86U + AC66U_B1
2. AC66U_B1 + Asus Lyra mini (3-Pack)
No problem with both Mesh systems.
VPN work as before - excellent
Beta 2 is now available. Changes since beta 1:
b2fb39a2ed Merge branch 'master' into mainline
2da320fae8 Updated documentation
d1bfe6ac98 Bumped revision to beta 2
8efbfeca8a getdns: listeners reply returned wireformat
136ff92387 Merge pull request #577 from Xentrk/master
1b6ab31f36 Merge pull request #576 from decoderman/master
83ce90d7b6 libovpn: fix policy client validation for CIDR-validated sources
19720598c6 Update vpnrouting.sh
37accd5251 Update vpnrouting.sh
14c2d36c1b Update vpnrouting.sh
a89e19699a Increased curl timeouts amtm FW
9a84171004 shared: rstats: removed a few unused nvram to regain some space
a803849beb webui: display appropriate warning message if jffs partition fails to mount instead of a low space warning
Just installed the beta2 firmware...
The OpenVPN DNS leak issue (exclusive DNS with CIDR formatted rule) has been fixed in this release, thank you.
For now, everything seems to work fine! :)
Thank you RMerlin. RT-AX88U and RT-AX58U updated and the first (@ 15-minute) reboot already completed with zero issues on my home network to Beta 2.
Fast and stable and everything working.
Same update procedure as the link above. :)
Just flashed both routers, only thing Ive noticed is I have no icon for open NAT, all other icons are there...NO biggie
I will reboot in 20 mins and report back
Working good. :) Thank You @Merlin. The change log is impressive.
Just updated to Beta2 and almost everything working..... But not this, maby some more $VPN_UNIT code.
May  5 07:05:23 (vpnrouting.sh): 1387 Starting routing policy configuration for client <===>
logger -st "($(basename "$0"))" $$ "Starting routing policy configuration for client $VPN_UNIT"
@RMerlin thank you for new beta!
Dirty flashed my AC86 today. After several unsuccessful attempts, I formatted the jffs partition and it updated on the next attempt. First time I've had any real problems updating Merlin firmware. Everything seems to be humming along now.
Dirty flashed to beta2 today--after waiting until yesterday to flash beta1. SAAB except I only attempted to update twice before formatting the jffs partition again. Again updated on first attempt after that. Beta2 now running as smooth as silk as far as I can tell.
Thanks for all the hard work, Merlin!
the frequent WAN disconnects still happen. I've tried using the same cable directly connected to the modem and no issues.
Updated both 86u units from beta1 to beta2. So far so good.
Interesting. I updated to Beta2 on my AC86U node but the main AC86U refuses to update to beta2 even after several attempts. Any suggestions other than a nuclear reset?
Just clear your browser cache or force a reload.
I corrected my update issues... I blew out both routers and installed ASUSWRT 386 RC3 on both routers. Up and running on my AiMesh system. :)
Dirty upgrade from beta1 to beta2, no problems or issues, all running smooth as silk. Thanks RMerlin!
Everything is good on on both of my RT-AX88Us. Thank you Eric!
