[Beta] Asuswrt-Merlin 384.8 beta is now available
left off the change log,
webui: allow changing image for device vendors with a quote (like "Micro-star int'l co., ltd.")​
I can happily report that I can assign the images for MSI based devices again :)
I have tested beta1 awhile, => Uptime 3 days 20 hours 47 minute(s) 8 seconds
Have discovered when use DFS channel in my case 100 or 112 and automatic switch to channel when detect "radar" to channel 36.
Gui on "system log=> wireless log" and "wireless=> general" channel not change to moved channel,
displaying channel 100 or 112 instead of channel 36.
@RMerlin
@RMerlin
The info I display is retrieved directly from the wireless driver, so it's outside of my control.
What? BRCM has bugs? Say its not so!!
In a prior life, we had direct support from BRCM to solve these kinds of issues. I'm sure Asus also has the level of support from them.
Asuswrt-Merlin 384.8 Beta is now available. As we bid farewell to the RT-AC56U (now officially EOL by Asus), we also welcome a newcomer, the RT-AX88U. The RT-AC87U and RT-AC3200 are not supported by this release (no updated binary blobs from Asus for these two models
I would say farewell to the AC3200 too, it's been 2 releases without support for this router :( :(
Not necessarily, Asus hasn't added it to the EOL list yet. The RT-AC3200 always had less frequent updates than other models.
I was having terrible problems with my RT-AC86 in bridge mode, and beta1 so far is working great! I was on 384.7_2 before, and I was rebooting sometimes every day just to get basic routing to work. It's a bit early to celebrate, but 384.8_beta1 has been running without any problems for just over two days.
Thanks for the continuous updates :) I need to wireshark my home my speedtest are utterly useless for me. I have to go to basement and plug into the ATT modem to get a general idea. Any help would be greatly appreciated this is the same laptop as well :)
http://www.dslreports.com/speedtest/42155382 this is on ATT modem
http://www.dslreports.com/speedtest/42155677 on the asus ac3100
s!Au7JwUjU2VLZzKtxy7e1SrQ3k7Wu6g
clean factory reset https://1drv.ms/u/s!Au7JwUjU2VLZzKtxy7e1SrQ3k7Wu6g
s!Au7JwUjU2VLZzKtwp0J5hHoM1_Puaw
restore from nvram utility https://1drv.ms/u/s!Au7JwUjU2VLZzKtwp0J5hHoM1_Puaw
Looks like going from scratch will be the best option? Suggestions?
Hello,
I have a problem with port forwarding , i'm unable to open any port from the WAN-> Port fowarding menu.
Do you guys have a trick to open port. I'm trying to open the port 57226 to go to one of my local machine
Thanks alot
384.8 Beta 2 is now available. Changes since beta 1:
04eef3934 Updated documentation
1af545344 HNDAX: merge with GPL 384_4736
7b149555c HNDAX: Merge RT-AX88U binary blobs from 384_4736
e6e3e19d8 openssl: updated to 1.0.2q
25159e362 webui: fix FAQ link on Adaptive QoS Bandwidth Monitor page
5b4838b31 webui: clarify fields for tunnelbroker DDNS configuration
3f1a1e2a2 httpd: fix certificate storage location
2a2302e5e kernel: add the TEE Netfilter target
e3c232790 kernel41-ax: add the TEE netfilter target
66985d615 kernel41-ax: sync config options with 4.1.27 (HND AC)
59e3a6704 Updated documentation
d4a1ba661 Bumped revision to beta 2
working fine so far..........:)
Uptime 0 days 0 hours 8 minute(s) 49 seconds
On the RT-AX88U I can't enable openvpn server #2
I haven't tried it yet on any other version then beta 2.
I've tried the default settings, the same settings as #1 (of course disabling #1 to test #2)
Somehow it keeps saying it failed to start.
