[Beta] RT-AC68U/87U/3200 9.0.0.4_380_2295-g1423616 Beta for checking bug in Network Map
But why in beta 9460 is more icon for client then in official fw 9460 ?
Wysłane z mojego SM-G920F przy użyciu Tapatalka
They are different development branch. This is why we need to release beta firmware, even if beta firmware version is the same as official firmware, they are still different.
Thanks,
Vanic
But on finish will be merged and in finish fw will be this more icon ?
We are waiting to merged your beta 9481 (with correct TA) with this beta 9460 (with correct NetworkMap) and release new version official...
And next beta should be relaese after merged all beta.
Jan 1 10:28:58 networkmap: Write to DB file!
Jan 1 11:00:12 networkmap: Starting full scan!
Jan 1 11:00:12 networkmap: reset client tables!
Jan 1 11:00:15 networkmap: Finish full scan!
Jan 1 11:01:20 networkmap: Write to DB file!
Jan 1 11:03:36 networkmap: Starting full scan!
Jan 1 11:03:38 networkmap: Finish full scan!
its normal for beta fw
Just let the guys at ASUS do their thing. Otherwise put in an application for a job :)
"3. Update client list in real-time to react offline or sleeping device"
Does this mean that new firmware will no longer wake up sleeping devices?
Hi Yiannis,
This point means device connect via WLAN(ex: smart phone) in sleep (or standby) mode will not show in the client list.
Wake up device issue still need more info.
Thanks.
Good option will be add other icon for switch lan. Now is for router only.
Hello ,
I have one asus RT-AC68U router with the Software release RT-AC68U_movistar.trx , this is a beta release for spain users because the Telefonica movistar ISP have especial requirements ( 3 vlans with PPOE). i see another routers have a official release in the asus webpage to download with this funcionality but RT-AC68U no.
its possible to download another beta than RT-AC68U_movistar.trx wityh this funcionality?
the version RT-AC68U_movistar.trx its very old and works properly but it have one bug with the tcp and upd timeouts...
can we help-me ? im advanced user and if you want i work with us to test the versions...
thanks and Regards
Roman
Kudos to the ASUS techs for being proactive and working with the users here. Many people wont spend the time testing and just return the router as bad. Users here are taking their personal time to report issues and to help ASUS resolve problems. Good to see ASUS finally using this site as a resource to actively fix issues people are having.
The thread fixing NetworkMap quickly was down...
Hello ,
thanks and Regards
Roman
puedes usar la de este hilo tranquilamente que va perfecta.
saludos
Hi Yiannis,
Thanks.
Hi Raw316!
I also support the request. We need a fix for wake up issue with some network devices. My Synology NAS is waking up every first minute of each hour with recent firmware versions. Seems that issue is related with network map and is affecting a lot of different devices and manufacturers.
Thank you.
Yes, same here
Sent from Galaxy S6 w/ Tapatalk
The last beta I've seen on .380_xxxx was the 1031. After that I didn't see any new for 87U :(
Thanks, since I don't have an access to beta code, how's that working? new qtn sdk has been integrated? bat drain?...are these long time issues fixed in your beta? And any possibilities that ASUS would release 380 based beta to public? sorry for too many askings...
Appreciate sharing your experience and thoughts.
Its been a month since this BETA has been out and tested.
When are we likely to see an official release with this fix in it please? - are we going to have to wait the usual 3 months?
