john9527
Part of the Furniture
Normal....means QoS is working....htb qdisc 15: is non-work-conserving?
Slow week for beta releases or a non-beta from Asus![]()
Asus@SG said:We are currently working on the next build and the new version contains fixes user interface, IPTV issue and improve the battery drain issue.
Sorry for late reply due to Comex show..
Asus@SG said:MU-MIMO is ready and we didn't enable at the moment, until we have fully resolved the 5Ghz issue.
I'm currently testing _8715. I didn't share it yet because it still has the battery drain issue on 5Ghz band.Slow week for beta releases or a non-beta from Asus
Sent from my iPhone 6 using Tapatalk
I'll be posting a new one soon
Replied through Tapatalk
Its mostly on Android devices.Look forward to it. Noticed no battery drain on any FW with my iphone.
Bodean share please 8715
Wysłane z mojego SM-G850F przy użyciu Tapatalka
You dont have this firmware?
There's a reason that I usually stay away from the bleeding edge...as this is messy
Anyway before getting MU-MIMO enabled, first we need beamforming working, if not forget about MU-MIMO
I am sorry to post this off-topic response but I get this question all the time. The short answer is no. And yes, the R and U variants are identical.DaveMishSR
I see that you have installed firmware v56 alpha 1. Where you download it ? Can you share me it on my Asus RT-AC87U ?
It is the same as RT-AC87R ?
I think for most folks - getting 5GHz stable on the QTN radio is critical path for the RT-AC87U customers - 5GHz stability on that target seems to be the cause of most issues...
Beamforming is optional in 11ac, as is MU-MIMO - but there's still some benefit to have 4*4:4 SU-MIMO...
For the ones curious to know what's new these are the expected changes in 56 once out.These builds can be very unstable, have no changelog or support and I generally recommend that most end users avoid them.
378.56 (xx-xxxx-2015)
- NEW: Merged with GPL 7838.
- NEW: Support for Russian ISP Telenet (code by theMIROn)
- NEW: ipset support in dnsmasq (patch by ryzhov_al)
- NEW: default loglevel is now configurable and defaults to 5 (notice) instead of 0 (emergency)
- NEW: local syslogd loglevel is now configurable through the webui.
- NEW: Support for extra-certs in OpenVPN
- CHANGED: Updated miniupnpd to 20150723 snapshot
- CHANGED: Updated openvpn to 2.3.8
- CHANGED: Updated dropbear to 2015.68
- FIXED: Router crash when an invalid or corrupted DH parameter is used on an OpenVPN server configuration.
- FIXED: 2.4 GHz temperature would be missing on the Sysinfo page when disabling thee 5 GHz radio on the RT-AC3200.
- FIXED: Max tracked connection limit wasn't user-editable
- FIXED: Resource leaks in ez-ipupdate if an update failed
Any chance you can repost this firmware, as the link doesn't seem to work anymore and I would like to try it, currently on 3.0.0.4.378_7449, which seems ok, with devices showing up as 5GHz connected (iPhone and iPad).
Pete.
Welcome To SNBForums
