CakeQOS CakeQOS-Merlin
New release v0.0.6
- Implemented watchdog (it'll be installed automatically when starting script)
- No need anymore to do install nor enable. When doing cake-qos start XXMBit XXMBit "param" the script will auto do the necessary things
- Readme updated with new instructions
- Bugfixes
Just remember that this is a WIP, so it MAY have bugs. Please test it and report it on github issues page. Thanks
Thanks...thread updated!
tried autorate-ingress
it was applied to both UL and DL queues.
the rates were constantly changing. sometimes the UL limit was set to high and the DL limit to low.
not using for now.
Agreed. I wanted to try this myself and found the same as you. bufferbloat was horrible.
Apologies for bumping my own post, but I think it got lost at the end of page 12 during a flurry of other update activity.
https://www.snbforums.com/threads/release-cakeqos-merlin.64800/page-12#post-596028
In short, can cake handle enabling itself on upload without applying itself on the download queue. Handy to have for people whose download rates exceed 300Mbs, but still want upload queue management.
Suggest that the script interprets a 0Mbps rate as "disable cake on that queue".
There may be a chance that cake has this built-in, it's worth a try :) I know at least for OpenWRT SQM if you leave one of the speeds as 0, it won't apply.
Try something like:
cake-qos start 0Mbit 30Mbit
Try something like:
it removed the DL limit:
CakeQOS-Merlin - v0.0.6: > Download Status:
qdisc cake 800a: dev ifb9eth0 root refcnt 2 bandwidth unlimited diffserv4 triple-isolate nat wash ingress ack-filter split-gso rtt 100.0ms noatm overhead 18 mpu 64 no-sce
but DL is still ~330Mbps
Yes, thanks, that's what I am talking about. It needs to remove cake from the interface entirely to remove the bottleneck.
@L&LD did you get 400Mbps with cake on an AX88?
Interesting. If the ax88u is faster, that means that cake must be using additional threads somewhat effectively then? (Since the individual cores and clock speeds are the same as the ac86u)
It looks like it still defaults to besteffort if none is specified.
Any reason to use that as default rather than use the cake diffserv3 default?
From: https://www.bufferbloat.net/projects/codel/wiki/Cake/
"We have generally found that most diffserv inbound priorities are wrong, so we tend to specify besteffort here"
Also apparently lighter on CPU usage (as it's just 1 "tin" vs 3, 4 or 8), but I'd be interested in seeing test comparisons between them.
with best effort only selected
Besteffort effectively ignores DSCP values, every packet is as important as the other and so just flow & host fairness come into play.
The diffserv modes split DSCP into an increasing number of tins.
