SHAPER PARAMETERS
CAKE uses a deficit-mode shaper, which does not exhibit the initial
burst typical of token-bucket shapers. It will automatically burst
precisely as much as required to maintain the configured throughput.
As such, it is very straightforward to configure.
unlimited (default)
No limit on the bandwidth.
bandwidth RATE
Set the shaper bandwidth. See
tc(8) or examples below for
details of the RATE value.
autorate-ingress
Automatic capacity estimation based on traffic arriving at this
qdisc. This is most likely to be useful with cellular links, which
tend to change quality randomly. A
bandwidth parameter can be used
in conjunction to specify an initial estimate. The shaper will
periodically be set to a bandwidth slightly below the estimated rate.
This estimator cannot estimate the bandwidth of links downstream of
itself.
