CakeQOS CakeQOS-Merlin
thanks @rgnldo
"dual-srchost", from reading the man page, sounds like something that one should always use, along with "ack-filter". thanks!
Both used by default (dual-srchost is included in triple-isolate) I believe
qdisc cake 800e: dev ifb9eth0 root refcnt 2 bandwidth 17Mbit diffserv4 triple-isolate nat nowash ingress ack-filter split-gso rtt 100.0ms ptm overhead 22 no-sce
qdisc cake 800d: dev eth0 root refcnt 2 bandwidth 5Mbit diffserv4 triple-isolate nat nowash ack-filter split-gso rtt 100.0ms ptm overhead 22 no-sce
EDIT - Clarification
Both used by default (included in triple-isolate) I believe
maybe slightly different (dual-srchost vs triple-isolate)?
https://lists.bufferbloat.net/pipermail/cake/2016-October/002288.html
from man page:
dual-srchost
Flows are defined by the 5-tuple, and fairness is applied first
over source addresses, then over individual flows. Good for use on
egress traffic from a LAN to the internet, where it'll prevent any
one LAN host from monopolising the uplink, regardless of the number
of flows they use.
dual-dsthost
over destination addresses, then over individual flows. Good for use
on ingress traffic to a LAN from the internet, where it'll prevent
any one LAN host from monopolising the downlink, regardless of the
number of flows they use.
triple-isolate (default)
Flows are defined by the 5-tuple, and fairness is applied over
source *and* destination addresses intelligently (ie. not merely by
host-pairs), and also over individual flows. Use this if you're not
certain whether to use dual-srchost or dual-dsthost; it'll do both
jobs at once, preventing any one host on *either* side of the link
from monopolising it with a large number of flows.
@rgnldo sounds like the default would be the safer choice? or dual-srchost better for asymmetrical connections?
with "docsis unlimited ack-filter dual-srchost" i just got 330/17 bufferbloat A on dslreports.
latency was good even with multiple clients in use.
remove ack-filter
I am thinking of CakeQoS as a solution for reducing latency and network congestion. For this reason I am trying to adapt the autorate-ingress solution. Who knows, CakeQoS will be an unbound or dnsmasq plugin ;)
You never know. But we need to get more routers supported :(
It would be your CakeQOS solution activated. Unbound is loving it, with high HIT rates
not sure i follow. how does cakeos help unbound's hit rate?
Take the test with the configuration I demonstrated. Then go back to yours.
will test.
"docsis ack-filter triple-isolate"(default) vs "docsis unlimited dual-srchost" ?
If I'm not mistaken, this is a ISP/client connectivity method. It is?
yes. specifies the packet overhead i think. docsis is cable
just tested.
on my comcast connection, dslreports got worse UL bufferbloat when i removed ack-filter
@rgnldo what are your thoughts on triple-isolate vs dual-srchost?
just tested.
triple-isolate can be applied equally to both upload and download with good effect, reading the manual you'll need to apply dual-srchost to your upload and dual-dsthost to the download which needs you to edit the script.
