heysoundude
Part of the Furniture
right...forgot it was on github. thanks
After doing an cake update, do I need to reboot, or will cake right itself at the top of the hour, or did it take immediately after updating? Looking at the logs, that suggests to me that cake was stopped, then updated, then restarted with the new version. Is anything else needed?
Here's what I get. What does this tell me?
CakeQOS-Merlin: > Download Status:
qdisc cake 800d: dev ifb9eth0 root refcnt 2 bandwidth 107Mbit besteffort triple-isolate nat wash ingress no-ack-filter split-gso rtt 30.0ms noatm overhead 18 mpu 64 no-sce
CakeQOS-Merlin: > Upload Status:
qdisc cake 800c: dev eth0 root refcnt 2 bandwidth 5400Kbit besteffort triple-isolate nat nowash no-ack-filter split-gso rtt 30.0ms noatm overhead 18 mpu 64 no-sce
I am curious as well, on my test platform I have 1.0.2 installed. (I installed it and forgot about it. been workin every sinceWhat's changed with from 1.0.2 to 1.0.4?
Same settings as before when you were using .2?Any way to roll back to 1.0.2? Either that or I have to reinstall it.. I did a hard reset after updating to 1.0.4. and gaming feels really choppy
I believe you guys are referring to the 86u.
Current Supported Routers: RT-AC86U & RT-AX88U
Thank you for the scripts. Maybe, just maybe we're getting closer for an amtm cake release...jk!
Welcome To SNBForums
