CakeQOS CakeQOS-Merlin
As long as you know what needs to be run to "start cake" again, you can manually add lines similar to these as a test:
Bash:
#!/bin/sh
if [ "$1" = "restart" ] && [ "$2" = "wrs" ]; then { sh /jffs/addons/cake-qos/cake-qos.sh checkrun & } ; fi
if [ "$1" = "start" ] && [ "$2" = "sig_check" ]; then { sh /jffs/addons/cake-qos/cake-qos.sh checkrun & } ; fi
Test at your own risk since I can't test this myself. But this is the same checkrun command that runs at the top of every hour in the cake-qos script.
I also wouldn't encourage everyone to do this yet, because if it ever gets added to the main script, it will be a pain to deal with these manual entries and any entries the script may want to add in the future, and avoid duplication.
Many thanks!
Did a manual Trend Micro check, Cake died, at top of the hour your solution restarted Cake.
Worst case scenario, Cake will be missing in action for <1 hour.:)
Many thanks!
The top of the hour check is already built into the script. My snippet should have been immediately run, but maybe there's a timing issue. May as well uninstall Cake and install FlexQoS (trojan horse warning!) :cool:
Chuckle!
Already included you say?! Maybe I should have tested that. :rolleyes:
Back to the drawing board.......
VPN is for security and will interfere with QOS. Chose one or the other
Further explanation here - Cake SQM traffic shaping is connection based - and OpenVPN being application layer, all traffic goes thru that one connection flow.
Isn't the larger problem the fact that this still only works with two of the Merlin-supported router models?
Also, back on my favourite topic of DSCP tagging. Has anyone had a look at seeing if tagging can be added to this script such as is done in OpenWRT? https://forum.openwrt.org/t/using-dscp-for-qos/14252/9
My own exploration only served to confirm how much I have yet to learn ;).
Yes, that is a problem...but when older models cease to be supported (and I suspect a rather significant cull in a short bit), it will cease to be an issue. sorry (not sorry) to say it, but that's the facts of the matter.
Having no idea what you meant by DSCP tagging, I took to wiki: https://en.wikipedia.org/wiki/Differentiated_services
Yikes...those IETF people have a lot on their plates!! Nice to see my chosen QoS method is ahead of their curve.
For Cake SQM - you have to define the limits - no limits means it's disabled
using zero as the limit enables "Automatic" and in my testing it's not as good as setting the limits.
The classification world is not a fun place to live. There is always changes and that mess up the classification and new apps you need to address. If you want to live in that world, use Adaptive QOS and add Flex-QOS.
It's not my policy :) Just that amtm will not adopt scripts that do not work on the majority of Merlin-supported models.
I'd personally be happy to see it included, and let any future Merlin supported models gradually be added to the cake list :).
Your chosen QoS method can make use of DSCP to better manage the traffic flows. That's what the Diffserv4, 8 etc models mean. Traffic gets classified, and then binned, and then the bins can be treated preferentially on top of the normal Cake queue management system. It's a Cake enhancement.
As Cake it right now, Diffserv modes are practically useless unless you are somehow receiving pre-classified traffic on your Asus router. That's why Besteffort is the current best choice.
Keep it simple, and just works...
@thumper:~# tc -d qdisc
qdisc noqueue 0: dev lo root refcnt 2
qdisc fq_codel 0: dev eth0 root refcnt 2 limit 10240p flows 1024 quantum 1514 target 5ms interval 100ms memory_limit 4Mb ecn drop_batch 64
qdisc cake 8009: dev eth1 root refcnt 2 bandwidth 90Mbit besteffort triple-isolate nonat nowash no-ack-filter split-gso rtt 100ms noatm overhead 44
qdisc ingress ffff: dev eth1 parent ffff:fff1 ----------------
qdisc noqueue 0: dev br-lan root refcnt 2
qdisc noqueue 0: dev wg0 root refcnt 2
qdisc noqueue 0: dev wlan0 root refcnt 2
qdisc cake 800a: dev ifb4eth1 root refcnt 2 bandwidth 90Mbit besteffort triple-isolate nonat wash no-ack-filter split-gso rtt 100ms noatm overhead 44
@thumper:~# tc -s qdisc
Sent 0 bytes 0 pkt (dropped 0, overlimits 0 requeues 0)
backlog 0b 0p requeues 0
Sent 227107635 bytes 185514 pkt (dropped 0, overlimits 0 requeues 2)
backlog 0b 0p requeues 2
maxpacket 1514 drop_overlimit 0 new_flow_count 1 ecn_mark 0
new_flows_len 0 old_flows_len 0
Sent 360807553 bytes 482490 pkt (dropped 17, overlimits 206314 requeues 46)
backlog 0b 0p requeues 46
memory used: 444928b of 4500000b
capacity estimate: 90Mbit
min/max network layer size: 28 / 1500
min/max overhead-adjusted size: 72 / 1544
average network hdr offset: 14
Tin 0
thresh 90Mbit
target 5ms
interval 100ms
pk_delay 53us
av_delay 32us
sp_delay 19us
backlog 0b
pkts 482507
bytes 360826123
way_inds 5797
way_miss 2120
way_cols 0
drops 17
marks 0
ack_drop 0
sp_flows 1
bk_flows 1
un_flows 0
max_len 60560
quantum 1514
Sent 957709433 bytes 811305 pkt (dropped 0, overlimits 0 requeues 0)
Sent 968068503 bytes 810645 pkt (dropped 660, overlimits 732094 requeues 0)
memory used: 434Kb of 4500000b
min/max network layer size: 46 / 1500
min/max overhead-adjusted size: 90 / 1544
Tin 0
thresh 90Mbit
target 5ms
interval 100ms
pk_delay 134us
av_delay 31us
sp_delay 4us
backlog 0b
pkts 811305
bytes 969067703
way_inds 2858
way_miss 2235
way_cols 0
drops 660
marks 0
ack_drop 0
sp_flows 1
bk_flows 1
un_flows 0
max_len 1514
quantum 1514
